Post by moff on Jul 17, 2016 16:37:56 GMT
Hi All,
Thought I would start a thread about our Race Car, some of you may already know about it ? Not an MX5 I know, but fun all the same
There has been a blog going since 2008, which can be found at The Project Moff | TMS Motorsport
The car is a Nissan Skyline R33 GTS-t Spec 2. That has been fitted with a fully forged RB26 Engine from a GTR with a Garret 4096R Turbo, pushing just over 600 BHP top the rear hubs.
Currently as it stands, the car looks like this
Full Spec list is :
Engine
RB26 Red painted engine (from an R32 GTR)
Garret 4094R Turbo (Oil and Water Cooled)
HKS F Con Pro Gold Ecu (version 3.2)
Wossner Pistons
PEC Rods
ACL Race Bearings
Stage 1 Abbey Motorsport modified Head
HKS Camshaft 264 Duration - 10.0mm Lift - Inlet
HKS Camshafts 272 Duration -10.2mm Lift - Exhaust.
Balanced Crank, flywheel, front pulley
Top Mount Manifold
Denso 720cc injectors
HKS Oil pump
N1 Water Pump
HKS Gaskets and seals
Greddy External wastegate
Trust 100mm FMIC
Mocal 34 Row Oil Cooler
50mm Japspeed Radiator
Nismo Fuel Pump
Splitfire Coil Packs
Rips modified GTR sump, with diff removed, welded, extended and baffled
Cold start system removed
Cabin heating systems removed from engine
Greddy Fuel Rail
R34 GTR Engine Loom
Greddy EGT Gauge
Greddy Profec B Boost controller
HKS Hard Pipe Kit
K&N Super Huge 100mm intake Filter
Air Con Removed
Carbon Canistor Removed
RB25DET Gearbox
Vibratechnics Custom Race Engine Mounts
Dry Fuel Brake System
Exhaust
Japspeed Silenced De-Cat
V-Band 80mm Turbo Elbow & Downpipe
Japspeed spec 1 cat back exhaust
Drivetrain
Heavy Shockproof Gear Oil
Silkolene Diff Oil
Nismo Pro S 1.5 Way Rear Diff with extended cooling fins
HKS Triple plate Clutch
Suspension
Cusco Front Strut Brace
Cusco Rear Strut Brace
Driftworks Rear Camber and Caster Arms
Cusco Front Camber Arms
Polished Stainless Hicas Lock Bar
Driftworks Front Tie Rods
Tein Track Rod Ends
Tein Track Rods
Poly Subframe Bushes
Driftworks Rear Traction Arms
Ohlin Coilovers (Rebuilt to full track spec)
Exterior
Full Respray (coming soon)
Nismo Bodykit
Custom front Splitter and undertray
Carbon Nismo 'B' Pillars
Custom made Carbon Kevlar bonnet
Custom Carbon Kevlar wider front wings
Carbon Flush fit rear bootlid
Carbon Rear adjustable Spolier on custom footplates
Custom Sand Blasted, etched and powder Coated front and rear subframes
Dual HID's 600k 55w. Main and Dipped Beam
Interior
Tinted Windows
Corbeau Evolution Carbon Kevlar Drivers Seat
Sparco Formula D Suede Steering Wheel
Snap off Steering boss kit
Extended steering boss
Apexi Dual Turbo timer
Greddy Profec B2 Boost Controller
Stripped and painted interior
HKS Boost Guage
TRS 3" 4 Point Harnesses in Red
Andy Robinson FIA Approved 7 point Roll Cage with Door Bars
Greddy 60mm EGT Gauge
Greddy 60mm Oil temp Guage
Greddy 60mm Oil pressure Guage
Stack Water Temp Gauge
Custom Carbon Door Cards
Brakes
Nismo Steel Brake lines
Stoptech 355mm Front and Rear Discs with Aluminium Hubs
Stoptech 6 Pot Front Calipers
Stoptech 4 Pot Rear Calipers
DS3000 Pads
Custom Moff made brake stopper
RBF600 Racing Brake Fluid
Wheels & Tyres
18 x 11J Rota MXR Rear ET+8
18 x 10J Rota MXR Front ET+12
Toyo 888's 285/30/18 Rear
Toyo 888's 265/35/18 Fronts
Power
At 1.4 Bar Turbo Boost pressure
Peak Power 605 BHP @ 7816 Revs @ Hubs
Peak Torque 445 lb/ft @ 6310 Revs @ Hubs
Full Spec list is :
Engine
Wossner Pistons
PEC Rods
ACL Race Bearings
Top Mount Manifold
HKS Oil pump
N1 Water Pump
Trust 100mm FMIC
Nismo Fuel Pump
Greddy Fuel Rail
R34 GTR Engine Loom
Greddy EGT Gauge
HKS Hard Pipe Kit
Air Con Removed
RB25DET Gearbox
Exhaust
Drivetrain
Silkolene Diff Oil
Suspension
Tein Track Rod Ends
Tein Track Rods
Exterior
Nismo Bodykit
Interior
Tinted Windows
HKS Boost Guage
Brakes
DS3000 Pads
Wheels & Tyres
Power
