Post by scottydugg on Jun 23, 2022 8:37:14 GMT
A haiku on the latest issue:
Need more fuel, Stop for Premium juice, Fuel gauge dead.
This is the first time I've genuinely had the thought, maybe it's becoming too much hassle, but then I don't know what I'd replace it with. I think I need to push on with the plans and if it doesn't work out know where to draw the line.
Post by scottydugg on Jun 27, 2022 10:30:09 GMT
So what do you do when everything starts failing, crack on anyway. Little steps, that's how I plan on getting this done. Cars now up in the air, under tray off and what's that leak I see? I think it's power steering fluid, more investigation required. So, this is what it looked like, a reminder to future me what a working car looks like: IMG_20220626_164245 by Scott Reid, on Flickr Went to fit up the manifold and the head stud holes required some persuasion to get them to fit correctly, ports lined up fine, but the holes needed some material taken off. Ended up taking the turbo off again to sort this out. Also bent the coolant hardline towards the firewall as per the FM guide and notched the frame rail (will lacquer later): IMG_20220626_210220 by Scott Reid, on Flickr Once the manifold was back on, re-installed the turbo and the downpipe elbow and fitted it up: IMG_20220626_230142 by Scott Reid, on Flickr You can see, that I've not clocked the compressor housing enough, currently the outlet points directly at the coolant pipe, I've since relocked and marked up the new holes needed for the actuator, so I'll get this dropped off over the next couple days, it looks like everything will clear nicely. Although with the compressor clocked to it's final position, everything won't slide on without tilting the engine towards the drivers side. IMG_20220626_230149 by Scott Reid, on Flickr Quick plan view of the assembly (pre-re-clocking), you can see how close the heater matrix hoses and passenger front brake line are to the hot stuff, I had bought some 30mm heat sleeve for the heater hoses, but I think it'll need 35mm to get round the bends. Going to try bend the brake line towards the fire wall and get some heat sleeve for it. IMG_20220626_230323 by Scott Reid, on Flickr The only real concern I've got left is the downpipe itself, I've not been able to test fit, the only saving grace being I run a decat currently, so if I need a different length to match up it's not going to break the bank. I just hope the downpipe elbow and downpipe meet up at the correct angle! Plan is to strip the front bumper off, then drill the pan next, or mock up the turbo assembly without the compressor housing and try out the downpipe. As a reminder for myself, I've also got to: - Replace Drivers front caliper. - Replace front discs. - Replace diff oil and check PPF alignment. - Check-over steering rack.
Post by atlex on Jun 27, 2022 21:03:05 GMT
Looking good :-)
If you can't return the 30mm heat wrap you can creatively apply (cut it..) it and still get good effect.
Post by scottydugg on Jun 30, 2022 8:19:01 GMT
Collected these last night for replacing the HSD's, MeisterR Clubrace, just need to get an adjustment spanner. They're in really good condition, 2 years old and only usef predominantly for 4 track days, all the collars are loose. Not sure if I'll get coilover socks yet. 2022-06-30_09-09-37 by Scott Reid, on Flickr
Post by boggissimo on Jun 30, 2022 8:44:16 GMT
Wow those look great for 2 years old. I'm going to get some ZetaCRDs probably, the spring rates on the Clubrace are probably too much for the back-road rallies I do. Socks are definitely a good idea (unless you never drive in the wet)
Post by atlex on Jun 30, 2022 9:25:59 GMT
Get the socks, blast them with ACF50, Put the socks on, and enjoy.
<B Meisters.
I'm glad I can run them here but would love to be able to run them on my MR2 also. I'll probably got with a TUV option tho.
Post by scottydugg on Jun 30, 2022 14:48:12 GMT
Wow those look great for 2 years old. I'm going to get some ZetaCRDs probably, the spring rates on the Clubrace are probably too much for the back-road rallies I do. Socks are definitely a good idea (unless you never drive in the wet) Yeah, great deal on them, I think they're 12/7kg spring rates, the CRD are 6/5kg on default. Most run the CRD in the middle stiffness or higher so I'm hoping these won't be too bad. I'm almost certain my HSD Dualtech's have the stiffer springs, but they came with the car. Long as these are softer than that. Get the socks, blast them with ACF50, Put the socks on, and enjoy. <B Meisters. I'm glad I can run them here but would love to be able to run them on my MR2 also. I'll probably got with a TUV option tho. Got the ACF50 from your recommendation previously I think, I'll get some of the Tegiwa socks ordered up.
Post by scottydugg on Jul 4, 2022 9:33:18 GMT
Spent 2 hours changing over the discs and pads on the wife's car, so since I was on a roll, thought I'd spend some time on the Mazda. I've mocked up the intercooler in position, I've had to remove the return edges and stud that would have held the A/C condenser coil, but that's no issue as it's long gone. The air guide needs a bit of trimming but nothing major, the tray that sit's under the engine will need a bit more surgery to clear pipework though. I think it's sitting pretty centrally, my aftermarket horn doesn't clear now though so that'll need some investigation. Not sure if I'll put the 2 bolts through the guide into the bottom of the intercooler like some folk do yet or not, I'll see how solid it is with the pipework in position. IMG_20220703_180522 by Scott Reid, on Flickr Now here's the bit that might cause some consternation, I thought everything's going so well let's just keep going, next thing I know I've drilled a hole in the pan. Everything you read says "oh it wasn't so bad", "it was easy", "what metal shavings!". I did not enjoy this one bit, now I know in an ideal world you'd remove the engine to do this, but I neither had the space or the required equipment for pulling an engine - which made the potential for disaster all the more anxiety inducing. Anyway it's done, I cleaned and re-greased the drill bit/tap more than I probably needed to, but better to err on the side of caution. I've still to drain the oil and flush everything through with white spirit, but I was going to hold off on that and send some snow foam down the bores to clean the piston rings. IMG_20220703_171420 by Scott Reid, on Flickr Fitting in place with some JB-Weld for good measure, it's solid and seems in a good position for clearing the steering rack lines. I know FM say to drill 2 inches down, but that's more for those with A/C to contend with, so it's roughly 45mm down. IMG_20220703_172913 by Scott Reid, on Flickr I'm waiting on the turbo compressor cover being re-drilled, before I can fit up the turbo, so I'll crack on with the intercooler for now and swap the bumper over. If it's still not back by the time all that's done I'll get the Meister's fitted up. Only unknown at the minute is how the downpipe will fit up with everything.
Post by scottydugg on Jul 11, 2022 15:19:28 GMT
Managed some time Friday evening and early Sunday, got the drivers front brake assembly swapped over, as well as removing the front suspension from both sides. Gave me a chance to treat the corrosion behind them I previously couldn't reach. IMG_20220708_222900 by Scott Reid, on Flickr Looks a bit like organised chaos. I've had to buy new suspension bolts, from Autolink, as those that came out had knackered threads, so it's a waiting game now, whilst I wait for parts to arrive.
Post by scottydugg on Jul 18, 2022 11:26:48 GMT
Bolts arrived so I've managed some more time on the car, looks like I'm missing this heat wave as well Finished up the front brakes then set about fitting the Clubrace, so far I've only done the fronts, but setup to the rears now. For reference here's what came out, they've done well but I think they were knackered when I got the car, I've never been sure on spring rates but I'm fairly certain it's the stiffer setup. Fine on a fair to good road surface, horrible on anything undulating, pockmarked, pot-holed (i.e. most UK roads), adding to that that the height adjustment was seized and 1 had lost all its suspension juice. IMG_20220708_211905 by Scott Reid, on Flickr Replaced with: 2022-07-13_09-20-59 by Scott Reid, on Flickr You can see the sheen from liberal doses of ACF50, going to get some coilover socks as well, but I keep forgetting to measure what size I need. Also trying to get a hold of this back box that's for sale near my parents, love a centre exit, so hopefully that works out. FB_IMG_1657922256488 by Scott Reid, on Flickr Supermiata engine mounts arrived thanks to thruxton (thanks again!), passenger side was easy with everything already removed and out the way. Drivers side was a bit more of a chew, although it was harder to get the old mount out than the new in. For the new mount it was just a case of assembling in position, it'd be easier for the US guys as they don't have to contend with a steering rack. IMG_20220717_113545 by Scott Reid, on Flickr You can't get it from the top: IMG_20220717_110614 by Scott Reid, on Flickr I've measured all my ride heights, I'm slightly too high on the front by about 0.25" (I think), I should be able to get it closer on the rear once I swap them over, hopefully able to get it close so I don't need an alignment straight away, to allow it to be tuned. I've ordered the majority of things I need to get first start-up: New Slave Cylinder, Engine Oil (5W30), Engine Filter, Diff Oil. Still to get: EBC unit, Coilover socks. My heat sleeve for the heater core hoses, did fit at 35mm dia. but looked absolutely rubbish (no photos), so I think I'm going to fit up some of the gold tape I've bought as a short term solution. I think I'm going to try and heat shield the whole area where the washer bottle was located or just get a turbo blanket, try protect it from some of the heat the turbo will produce, also a plan to fab up an air box for the intake eventually. Lots to do!
Post by howardb66 on Jul 18, 2022 11:39:06 GMT
Well done on getting the engine mounts done. The drive’s side one is a right pain isn’t it?
Post by scottydugg on Jul 18, 2022 14:08:38 GMT
Well done on getting the engine mounts done. The drive’s side one is a right pain isn’t it? Yeah it wasn't the easiest, one of the guides I read online said getting the bolts back in the block would be the worst bit, getting the actual thing in position and built up one handed was by far the worst bit! How do you find yours now you've fitted them? It'll be a while before I can drive it again.
Post by howardb66 on Jul 18, 2022 17:26:04 GMT
Well done on getting the engine mounts done. The drive’s side one is a right pain isn’t it? Yeah it wasn't the easiest, one of the guides I read online said getting the bolts back in the block would be the worst bit, getting the actual thing in position and built up one handed was by far the worst bit! How do you find yours now you've fitted them? It'll be a while before I can drive it again. There doesn’t seem to be a downside with no change in NVH. Gear change is better & the engine feels much more solid.
Post by scottydugg on Jul 25, 2022 10:18:45 GMT
Another Monday another update, I've tentatively booked the tuner for his next trip onshore so I've got a deadline now. So with the engine mounts swapped over, I was ready to fit the turbo assembly, so fitted up the turbo oil feed, which came from black cat a nd is fed off the side of the block, added some of the orange heat shielding to tie in with everything else. IMG_20220722_212942 by Scott Reid, on Flickr Compressor housing came back re-drilled, once it was fitted up I couldn't get the assembly on the engine anymore, so needed to tilt the engine over, needed clocking a little more to line up with the intercooler pipework but that was fine as it lined the actuator up better. Something they miss in the FM YouTube instruction video, the central nut on the manifold, I could only get it to tighten with the rest of the nuts on but not threaded and with a flare nut spanner, 1/8th of a turn at a time. IMG_20220724_151950 by Scott Reid, on Flickr I've fitted and routed both water lines, connected up the intercooler pipework both sides, connected the turbo oil drain (needed trimmed to length in the car), turbo oil feed will be tested cranking into a bag to prove oil does come out. Still need to cable tie the water lines up out of the way: IMG_20220724_142814 by Scott Reid, on Flickr No pictures yet, but I started mocking up the downpipe, I've been worried it'd not fit for a while, but early testing seems to show it should, now whether it lines up with the decat is another thing, as I couldn't get it on without removing the decat. there is a slip joint flexi on there, so hopefully I've some level of adjustment, as it's the longest cat length I have on there already. Looking how close the downpipe elbow is to both the passenger front brake line and heater matrix hoses, I think I'll try mock something up initially, before going with some proper heat shielding. They're pretty close, but it seems as though some folk just cable tie the brake line a little further out the way and be done with it. Just ordered up the a MAC EBC unit and a 76mm ID Ramair Proram filter, which seems to be on par with what the FM kit supplies, just need a 90 degree elbow to fit up to the turbo. I've also bought some 5w30 Millers oil, I always seemed to run higher oil pressure on the 5W40, but since I likely won't see 30deg. ambient (which going by searches is where they recommend 5w40), I'll try 5W30 this time, worst case I change back and use this as an oil flush, but I'm open to opinions. As an addition, it always seemed to run slightly higher after swapping to the BP4W head. I've still to fit the Meisterr's on the rear, but have removed the HSD's, a year ago I rust converted and applied Waxoyl, looking at how it's faired I won't be using it again, absolutely rubbish - flaking off and surface corrosion underneath - almost as if it promotes corrosion! I'll use POR15 next time round. Anyway, enough rambling for today.
Post by scottydugg on Jul 27, 2022 11:06:38 GMT
Video, click to watch: VID_20220726_204448 by Scott Reid, on Flickr The ticking is the drivers side wing vibrating, without the bumper it was rattling an absolute beast. I've got some oil and exhaust leaks that need resolved, it idles pretty happily and it does start, still got the high idle on cold start-up. I'll go back through all of the turbo bolts and give them all a tighten, the turbo oil feed restrictor is the main culprit for the oil leak. Good news is, now the IACV has been quietened down by the turbo, bad news is it's louder than I was hoping (I though the turbo would quieten it down a bit), it's going to sound wild on full chat! Before start up swapped in the colder set of plugs, current tune is looking good: IMG_20220726_192924 by Scott Reid, on Flickr Managed to get some heat sleeve on to protect the heater matrix hose: IMG_20220725_232535 by Scott Reid, on Flickr Filter items on order, should be here this week, along with the EBC unit. Can finish up fitting the Mesiter's next.
