Post by scottydugg on Oct 25, 2022 9:04:32 GMT
I need the Mazda back for daily duties for a week or two, so agreed with the tuner that I can pick it up Friday/Saturday. EBC isn't working so will need to look into that, we discussed fitting an MBC but with the weather the way it is, it'll break traction on waste-gate, that'll do for a couple weeks.
I'll change up to 5W40 whilst I've got it back and fit the Spiked Performance bonnet vents. Facebook Marketplace came through on the 2.5" exhaust (hopefully), only took 3 weeks to get the guy to sell me it! That'll get fitted before it goes back as it'll require a retune anyway.
Here's hoping all goes to plan.
Post by atlex on Oct 25, 2022 12:40:25 GMT
I recon 5w40 is perfect for a UK-based 'hard driven' mk1/mk2. Are you going to fit a knock sensor ?
Post by scottydugg on Oct 25, 2022 14:06:07 GMT
I recon 5w40 is perfect for a UK-based 'hard driven' mk1/mk2. Are you going to fit a knock sensor ? No I've not even looked into that yet, if it proves easy enough to do on the DIYEFI then I'll get something put in place. I'll need to read up on your posts and see what you did. He's got his hands on a manual boost controller, so we're going more boost from the off He's battling with the IACV, I think the one fitted is possibly dead/dying, I've got a spare to try and run.
Post by atlex on Oct 25, 2022 14:14:58 GMT
I recon 5w40 is perfect for a UK-based 'hard driven' mk1/mk2. Are you going to fit a knock sensor ? No I've not even looked into that yet, if it proves easy enough to do on the DIYEFI then I'll get something put in place. I'll need to read up on your posts and see what you did. He's got his hands on a manual boost controller, so we're going more boost from the off He's battling with the IACV, I think the one fitted is possibly dead/dying, I've got a spare to try and run. You'll need some two-wire shielded cable and a bosch donut sensor, along with some 2 pin JPT connectors. I'd also recommend some nice black nylon sheathing. I Expect DIYEFI will support knock. www.facebook.com/DIYEFI/posts/just-a-small-teaser-for-those-of-you-who-have-been-asking-about-knock-sensingthi/496465497550242/
Post by howardb66 on Oct 25, 2022 15:32:50 GMT
I recon 5w40 is perfect for a UK-based 'hard driven' mk1/mk2. Are you going to fit a knock sensor ? No I've not even looked into that yet, if it proves easy enough to do on the DIYEFI then I'll get something put in place. I'll need to read up on your posts and see what you did. He's got his hands on a manual boost controller, so we're going more boost from the off He's battling with the IACV, I think the one fitted is possibly dead/dying, I've got a spare to try and run. I’m running a manual boost controller, it’s about 12psi but it does marginally overboost sometimes to about 14 on the dial on high rev changes.
Post by scottydugg on Oct 26, 2022 8:36:40 GMT
No I've not even looked into that yet, if it proves easy enough to do on the DIYEFI then I'll get something put in place. I'll need to read up on your posts and see what you did. He's got his hands on a manual boost controller, so we're going more boost from the off He's battling with the IACV, I think the one fitted is possibly dead/dying, I've got a spare to try and run. You'll need some two-wire shielded cable and a bosch donut sensor, along with some 2 pin JPT connectors. I'd also recommend some nice black nylon sheathing. I Expect DIYEFI will support knock. www.facebook.com/DIYEFI/posts/just-a-small-teaser-for-those-of-you-who-have-been-asking-about-knock-sensingthi/496465497550242/Thank you, will do a bit more research into it, tuners been in contact with the DIY-EFI guy so hopefully get something sorted. No I've not even looked into that yet, if it proves easy enough to do on the DIYEFI then I'll get something put in place. I'll need to read up on your posts and see what you did. He's got his hands on a manual boost controller, so we're going more boost from the off He's battling with the IACV, I think the one fitted is possibly dead/dying, I've got a spare to try and run. I’m running a manual boost controller, it’s about 12psi but it does marginally overboost sometimes to about 14 on the dial on high rev changes. Thanks Howard, we're going for 0.8Bar/12psi-ish, are you thinking of going EBC in the future?
Post by howardb66 on Oct 26, 2022 10:42:01 GMT
I’m running a manual boost controller, it’s about 12psi but it does marginally overboost sometimes to about 14 on the dial on high rev changes. Thanks Howard, we're going for 0.8Bar/12psi-ish, are you thinking of going EBC in the future? Definitely, hopefully by Christmas. The EBC is fitted & wired up to where the carbon canister used to be, just need to solder a couple of posts together on the ECU & then get it mapped to work.
Post by scottydugg on Oct 26, 2022 12:36:51 GMT
Thanks Howard, we're going for 0.8Bar/12psi-ish, are you thinking of going EBC in the future? Definitely, hopefully by Christmas. The EBC is fitted & wired up to where the carbon canister used to be, just need to solder a couple of posts together on the ECU & then get it mapped to work. Yeah the DIY-EFI uses the same connection, but I think it's my wiring that's the issue. Do you know what bph you're running with the 12psi? Night and day to the supercharger setup power wise?
Post by howardb66 on Oct 26, 2022 12:41:37 GMT
It’s been on the rollers twice in the last 10 months, 239.7hp 1st time & 241.8hp the 2nd.
Post by scottydugg on Oct 31, 2022 11:47:22 GMT
Collected the car on Saturday, forgetting there were train strikes, so what should have been an easy journey turned into a bit of a faff. left the house at 10am, didn't get back till 5pm, the tuners only an hour or so away by car.
Anyway, where do I start, car still needs to go back to him for final tuning, the mx5 IACV is proving a bit of a pain, the mk2 crank sensor is working a treat though - it starts every time without excessive cranking. Still need to fit the: bonnet vents, 2.5" exhaust (which finally arrived after 4 weeks of chasing the guy). I'm dropping voltage under load so he suspects my alternator is on it's way out, so I'll get a new one from mx5parts. It's doing inconsistent things with my AFR's when hot and cold. It looks like the original 30 year old unit and I did try running a dying battery for a while, so no surprise there.
It's fitted with a manual boost controller for now, running 0.8/0.9Bar, first impressions: it's sodding quick, like most speeds feel quick in a 5 but when you actually go quick....it feels daft/silly speed. It's rained all weekend since I got it back, so I've not had a chance to test what it can do on some roads I know. The GT2554r runs out of puff after about 6k so it does drop off a bit, but there is literally no lag, none, squirt and go type of stuff.
The turbo noises are absolutely daft, especially the Forge BOV, potentially too much for what I'm after, but hearing the turbo start to spool is addictive, I've had other turbo cars before but this is another level.
I've since changed the coolant and the oil to 5W40, going to daily drive it for a while, he's back onshore the end of November so I'll get it back to him with all the snagging list completed.
Oh and I checked, 70mph is at roughly 3500rpm, it's just my tacho needle it fitted in the wrong place from when I did the dial faces.
I'll get some pictures/videos when I get a chance/it stops raining. Meanwhile I need to go relearn how to drive this thing.
Post by scottydugg on Nov 2, 2022 10:49:29 GMT
Strange things are a happenin' that can only be electrical in nature, new alternator ordered, will fit it this weekend. I might expedite the bonnet vents, parked up at work and the rain was steaming off the surface, under bonnet temps need reduced - my coolant temps are fine sat at 93 spiking to 95. Intake temps sit in the range of 30-40 depending on whether moving or stationary. howardb66 I would be interested to hear what temps you see? Also atlex, the catch can has made a large difference and hasn't filled up at all after quite a few miles thanks, will still look to fit one inlet side as you recommended. Also, overtaking in 5th gear is now a thing, it's made the wife's Corsa feel excruciatingly slow(er).
Post by atlex on Nov 2, 2022 14:00:04 GMT
Strange things are a happenin' that can only be electrical in nature, new alternator ordered, will fit it this weekend. I might expedite the bonnet vents, parked up at work and the rain was steaming off the surface, under bonnet temps need reduced - my coolant temps are fine sat at 93 spiking to 95. Intake temps sit in the range of 30-40 depending on whether moving or stationary. howardb66 I would be interested to hear what temps you see? Also atlex , the catch can has made a large difference and hasn't filled up at all after quite a few miles thanks, will still look to fit one inlet side as you recommended. Also, overtaking in 5th gear is now a thing, it's made the wife's Corsa feel excruciatingly slow(er). don't bother on the inlet er (exhaust side of the cam cover) side unless you're tracking the car. :-) the simplest solution is a hose to somewhere away from the exhaust in case something lets go and oil flies out.
Post by howardb66 on Nov 8, 2022 16:37:56 GMT
Strange things are a happenin' that can only be electrical in nature, new alternator ordered, will fit it this weekend. I might expedite the bonnet vents, parked up at work and the rain was steaming off the surface, under bonnet temps need reduced - my coolant temps are fine sat at 93 spiking to 95. Intake temps sit in the range of 30-40 depending on whether moving or stationary. howardb66 I would be interested to hear what temps you see? Also atlex , the catch can has made a large difference and hasn't filled up at all after quite a few miles thanks, will still look to fit one inlet side as you recommended. Also, overtaking in 5th gear is now a thing, it's made the wife's Corsa feel excruciatingly slow(er). don't bother on the inlet er (exhaust side of the cam cover) side unless you're tracking the car. :-) the simplest solution is a hose to somewhere away from the exhaust in case something lets go and oil flies out. Haven’t looked at the temps to be honest. I’ve vented my bonnet on the exhaust manifold side as that is the hottest side of the engine by far (using the tried & tested hand on bonnet test😂). Also got a cold air feed from the fog light hole up to the air filter.
Post by scottydugg on Nov 10, 2022 10:38:33 GMT
Got some pictures of the mk2 Crank sensor fitted up in position on the mk1 block, I'm not sure if he notched the sensor or the oil pump, but it fits in nicely, he's(tuner) ran the wiring along the COPS and down which seems to be working well. MK2 crank pulley fitted which accommodates the trigger wheel thickness. You can also see the BOFI lower rad hose, which I would recommend as it created a lot of space for intercooler piping, for anyone FI. Screenshot_20221015_131909_com.instagram.android_edit_924259495270425 by Scott Reid, on Flickr Screenshot_20221015_131918_com.instagram.android_edit_924269002063653 by Scott Reid, on Flickr Tuner advised, during a pull my voltage was dropping off, sign of an alternator on it's last swan song, which is not bad for what I assume is 30 years old - this one came with the replacement engine so we'd never removed it. Bought a new one from BOFI and set about removing the old.....can now confirm the worst bolt to remove on the car so far is the lower alternator bolt! I'm surprised it didn't snap, 2 hours to get the thing out - Disclaimer: I did everything from the top as I refused to put it on jack stands - alternator does come out you just need to remove your throttle body. Since the TB was coming off anyway to swap the IACV for a spare, happy days. Said bolt, you can see the threads on the end aren't really threads anymore: IMG_20221105_174242 by Scott Reid, on Flickr Old alternator vs new: IMG_20221105_175213 by Scott Reid, on Flickr I've not yet refitted it as whilst I was waiting for a new bolt, I started on the Spiked Performance bonnet vents. Not too bad to fit, I think I've cut the second out a lot better than the first but the vent flange, some touch up paint - will hide a multitude of sins. I used some Dremel Speedyclic discs and a grinder, I need to tidy up some of the internal edges with some trim if possible but it's gone better than I thought. Maybe pick up a spare bonnet in the future. Anyway, simple enough to fit, just apply the vinyl outlines they supply (trick is to wet the bonnet and the back of the vinyl), position to the measurements on the green tape and squeegee out the water. IMG_20221106_180921 by Scott Reid, on Flickr IMG_20221106_180854 by Scott Reid, on Flickr IMG_20221106_181117 by Scott Reid, on Flickr Cut the top layer with the Dremel and then came back through with the grinder on the under bracing, then finished with a file (handily it's aluminium). I got some dust sheets to cover the car and I'm glad I did, surprising amount of mess from 2 holes. IMG_20221107_204142 by Scott Reid, on Flickr First hole, you can see where I got a bit grinder happy: IMG_20221107_210101 by Scott Reid, on Flickr 2nd holes a lot better finish: IMG_20221109_183242 by Scott Reid, on Flickr Then it's a case of trim to line up with the green tape and drill some holes for the rivets, only done one so far as I wait for the touch up paint on the other side to dry. IMG_20221109_195032 by Scott Reid, on Flickr IMG_20221109_200122 by Scott Reid, on Flickr IMG_20221109_200126 by Scott Reid, on Flickr Quite subtle on a black car, sure they'd stand out more on a different colour, hopefully they make a difference on the under bonnet temps, next step would be the intake box. I might put some gold tape under the bonnet above the turbo, try alleviate the paint (and it'd look good). My intake side catch can has just arrived, which seems a bit better internally than the exhaust one I fitted, it's about sizes with a 330ml coke can, so I might try fit it to the strut brace - similar to how I fitted the EBC or to the charcoal canister bracket (if I can find it!), the non return valve hasn't arrived yet, I might get a barb fitting (10mm?) to the cam cover unless I can find my old knackered PCV to drill out. I do have some oil build up behind the throttle body, that's been there since before going turbo, so hopefully this resolves that or reduces substantially. Will update once I'm a bit further along.
Post by scottydugg on Nov 11, 2022 10:56:25 GMT
Last update for a couple days, but managed to get the new bonnet holes sorted out and rivet holes drilled, gone round everything with touch up paint and ordered some edge trim to help tidy it all up a bit. How they look from underneath the bonnet for anyone interested: IMG_20221110_184531 by Scott Reid, on Flickr Swapped out IACV for a spare unit and changed the screws over to some cap head bolts, I don't know how many of the screws I've had to replace to date, but hopefully these won't strip if I need to remove them. Also used some RTV to make up the gasket as I couldn't find anywhere that sold the OEM gasket: IMG_20221110_190551 by Scott Reid, on Flickr New alternator back in position and bolted up, not as difficult to put back in as I'd read, couple screw drivers through the bolt holes before attempting with the bolt. Refit the brace and tension up the belt, job jobbed: IMG_20221110_200001 by Scott Reid, on Flickr Close the bonnet, time for wrap everything up......Canoe. IMG_20221110_200642 by Scott Reid, on Flickr Will need to try move that a bit further under the bonnet, there's a straight connector connecting the filter to the silicone elbow, so hopefully it's just a case of a longer joiner and the filter still fits. Lots of lovely fresh air, but it rains too much up here to leave it like that, especially since it's angled upwards.
