Post by scottydugg on Jul 3, 2019 21:33:08 GMT
Very good. LEDs have a much better beam pattern compared to HIDs, thinking about some for my NB2. They were leds in the jeep headlights, but very cheap ones I'd guess. Leds in the low pro have fans in the unit. Speaking to the seller they cost more than the jeep headlights alone. Would recommend some.
Post by atlex on Jul 4, 2019 14:42:13 GMT
Very good. LEDs have a much better beam pattern compared to HIDs, thinking about some for my NB2. They were leds in the jeep headlights, but very cheap ones I'd guess. Leds in the low pro have fans in the unit. Speaking to the seller they cost more than the jeep headlights alone. Would recommend some. where'd you get'em ?
Post by scottydugg on Jul 5, 2019 11:09:51 GMT
They were leds in the jeep headlights, but very cheap ones I'd guess. Leds in the low pro have fans in the unit. Speaking to the seller they cost more than the jeep headlights alone. Would recommend some. where'd you get'em ? The LED's? I'll need to check with the I bought the low pro's from as he bought them. Let me ask him and I'll let you know.
Post by scottydugg on Sept 10, 2019 14:03:59 GMT
Update #3: In preparation for an upcoming road trip and with heavy rain forecast I thought I’d get the car up in the air for some maintenance/modification, this turned out to be bad timing with some of the hottest weather on record. What was meant to be a weekend of work turned into a 4-week ordeal……”if I’m doing that I may as well do this….and this….and that”….it escalated. So what’s been done since the last update, in a sweltering garage, with an out of commission convertible….in the hottest weather of the year. Revlimiter “Alpha” gauges fitted with some red needles, following the Revlimiter tutorial, with some white LEDS. I’ve always loved the offset rotation in comparison to stock, quality service was great so I’ll be buying more parts in the future. IMG-20190706-WA0005 by Scott Reid, on Flickr IMG_20190706_171723 by Scott Reid, on Flickr Jass Performance Heavy Duty Frame Rails fitted that were picked up locally, these would have been easy to fit if my frame rails weren’t crushed and my floor pan dented on the passenger side. In conjunction with the roll bar and inner wing stiffeners these have made a huge difference, reducing scuttle shake and rattles drastically, it now takes a bigger bump/undulation to unsettle the car now. I’ll maybe look into some door bars if a set pop up, but I’m in no rush at the minute. IMG_20190808_202531_614 by Scott Reid, on Flickr IMG_20190804_172035 by Scott Reid, on Flickr IMG_20190805_193808 by Scott Reid, on Flickr After trying out a budget bucket seat to see if it’s a direction I’d like to go in, the stock seats are great but I was having to brace against the door and transmission tunnel. Budget seat bought and test fitted, then sold as it had served its purpose. IMG_20190721_191315 by Scott Reid, on Flickr Proceeded to pick up a set of Cobra Clubmans locally that were previously fitted in a classic mini clubman, black vinyl with red piping. They’re in pretty good condition and have since been fitted with some GSM adapter brackets, which seem to come with no fitting instructions. IMG_20190809_170404 by Scott Reid, on Flickr IMG_20190809_223200 by Scott Reid, on Flickr IMG_20190809_201656 by Scott Reid, on Flickr IMG_20190809_201705 by Scott Reid, on Flickr First impressions: I think you sit slightly higher but not by much, support when going round a corner is great, no longer need to brace against the door/transmission tunnel. Compared to the other bucket seats I tried these are maybe more road focussed, after doing 6.5 hours in them recently I wasn’t in too much discomfort, certainly no more than the standard seats. Picked up some Willans 4 point harnesses in black and installed eyebolts so these can be run in conjunction with the standard seatbelts, these haven’t been fitted yet. I’ve been running an Ebay-special stainless manifold for the last year, due to cutting the stock manifold off due to seized bolts. As far as I can tell it’s just a copy of the stock manifold in stainless steel, short runners into 2” pipe back to the cat area. I found a cheap second hand mx5-Parts 4-2-1 manifold that collects into 2.25” that matches the rest of my existing system. IMG_20190803_162830 by Scott Reid, on Flickr IMG_20190814_222326 by Scott Reid, on Flickr Unfortunately, the change in manifold led to my silenced de-cat (370mm) being too short, so as a quick fix I got an M2 Motorsport unsilenced de-cat (440mm), benefit being that the full exhaust system is now stainless steel. Whilst I was there I also replaced all exhaust hangers with polyurethane. IMG_20190815_191324 by Scott Reid, on Flickr Serviced all the oils on the car following the BOFI Racing guide for the diff and gearbox, oils that were replaced had only been in there a year at best, the gearbox turret oil seems to go black fairly quickly as this is the third time I’ve changed it now. Engine oil replaced with fully synth Motul Sport 5W40 from OPIE OILS and a K&N oil filter (handy as it has a hex fitting on the end for fitting/removal). I’ve since replaced my Uniroyals with some Pilot Sport 3’s on the front, budgets moved to the rear as the excessive camber will chew through them in no time. Next task over the winter is un-seizing all the alignment bolts and fixing the 2 degree camber in the rear, which I think is causing the tendency to understeer when pushed. Just replaced the door speakers and looking to get a bit more bass so a slimline sub may be fitted if I can decide where to put it. Ideally where the spare wheel used to be as I’ve never used that. I’m also in the process of changing out all exterior bulbs to LED’s, as well as looking into the LED ring mod to the rear lights, I’ll do a comparison once complete. In bad news it looks like I’m going to need two new sills sooner rather than later (probably before the next MOT) so I’m starting to look into what it’s going to cost. I did consider splitting it and trying that 350Z I’ve always wanted, but I’ve been informed from the wife that that won’t be happening, I’m too invested in this one. Still plenty work to be done, still flirting with the idea of saving for some forced induction, we’ll see how far that gets, see what’s left after the rust is fixed. Couple pictures since it’s back on the road. IMG_20190819_201326 by Scott Reid, on Flickr #10 (Large) by Scott Reid, on Flickr Next to my dad’s mk1 TT, he bought it after we finished the mx5 as his next project. IMG_20190825_135340 by Scott Reid, on Flickr Thanks for reading. S.
Post by howardb66 on Sept 10, 2019 15:11:02 GMT
Good work. Do the sills & keep making progress! Try a 350/270Z..... You’ll want to stay with the 5!
Post by Whistler on Sept 11, 2019 6:07:22 GMT
I’ll maybe look into some door bars if a set pop up, but I’m in no rush at the minute. Do the door bars. You won't regret it... they triangulate the door and really stiffen the car up.
Post by scottydugg on Sept 24, 2019 9:17:59 GMT
Good work. Do the sills & keep making progress! Try a 350/270Z..... You’ll want to stay with the 5! Thanks Howardb66, I'm trying to source some replacement panels, I tried a 350Z once upon a time and decided on a mk2 Focus ST instead. My biggest car purchase regret, I'd always wanted one and it still lingers on, but I haven't tried one since getting so far with 5's. They're more of a GT with pace? I’ll maybe look into some door bars if a set pop up, but I’m in no rush at the minute. Do the door bars. You won't regret it... they triangulate the door and really stiffen the car up. Will have a look for a set, I'll need to check if they'll fit with my Cobra Clubmans. I'll get a request up for some dimensions once I measure what space I'm working with. In other news, the exhaust is now rattling off something considerable when pulling away, I have an inkling it's the ladder brace on the rear. Ideally an adjustment needs to be made when funds permit, but I seem to be at that strange crossroad where I've amassed a considerable pile of parts that I've not fitted!
Post by scottydugg on Jan 29, 2020 14:17:56 GMT
Quick update, the BP4W project is still under way, but with the car having gone and passed its MOT with no work required, getting the car sorted for the summer with all these salty roads can break up the never ending valve lapping. So first things first, the exhaust has been hitting the rear ladder brace since fitting, it's been an issue of constant irritant, any touch of the throttle resulting in a metallic rattle until a speed is achieved to drown it out with wind noise. So in a moment of clear and rash thinking I bought an ebay exhaust that's come off a BRSCC MX5 Race Car, made good power on BLINKS dyno apparently, Sold the MX5parts cat-back and can only hope this solves my problems rather than creates a new one (awaiting delivery). The cars also now up in the air for some maintenance/cleaning, since I was taking the exhaust off, plans are: - Clean the front wings out. - Treat and underseal any rust underneath. - Replace the seized drop-link I left last year. - Bumper cut the rear bumper. - Treat surface rust in the boot. - Replace all alignment bolts (they are all seized!) Also, fitted the hardtop to the car, after installing an MX5Mods headliner, that matches the door cards, a last minute black Friday purchase. Whilst in there I swapped my mk1 rubber screen surround for a mk2 version that wasn't split (I think they're identical), treating some surface corrosion hiding under the rubber. Before: IMG_20200126_135145 by Scott Reid, on Flickr After: IMG_20200127_001642_163 by Scott Reid, on Flickr Corrosion surprise: IMG_20200126_141451 by Scott Reid, on Flickr IMG_20200126_142124 by Scott Reid, on Flickr
Post by V6 on Feb 13, 2020 20:07:01 GMT
Your headliner looks stunning
Post by scottydugg on Feb 14, 2020 11:56:22 GMT
Your headliner looks stunning Definitely worth getting, Mx5Mods does some good stuff, I've bought a couple things from him. Thinking about the dash top cover next.
Post by scottydugg on Feb 17, 2020 14:26:02 GMT
After the car passing it's MOT I decided it was time to do something about the alignment, it's had one alignment in my time of ownership and at that time only the front could be adjusted. The rear has always been at a drift friendly 2 degrees, it chews tyres. I started by trying to loosen them, then snap them, I should have just cut them off, it would have saved a couple hours. IMG_20200204_222837 by Scott Reid, on Flickr These are the original D shaped design, I'm guessing they've never been changed. Replaced with the new design with 2 slots and thicker washers. With the car up in the air decided to refresh some of the underside: exhaust heat shield, 6 point brace, underseal. IMG_20200211_190652 by Scott Reid, on Flickr IMG_20200207_180909 by Scott Reid, on Flickr IMG_20200209_175203 by Scott Reid, on Flickr IMG_20200211_175232 by Scott Reid, on Flickr Managed to get a set of void fillers for the diff, should eliminate the axle tramp that I've been experiencing. Unfortunately found some snapped studs in the lower diff mounts, drilled these out and put everything back together. IMG_20200215_152302 by Scott Reid, on Flickr IMG_20200210_194421 by Scott Reid, on Flickr Sold my single exit MX5Parts exhaust as it was clashing and rattling off the underside. Been trying to source a replacement, got a dual exit MX5Parts cat-back (top) and a cobalt dual exit back box (bottom). IMG_20200213_180806 by Scott Reid, on Flickr Cut the bumper in preparation, IMG_20200212_201253 by Scott Reid, on Flickr IMG_20200212_202248 by Scott Reid, on Flickr IMG_20200212_205258 by Scott Reid, on Flickr Unfortunately, the cobalt doesn't line up enough with the mid pipe, so I'm in the process of fitting the MX5Parts. Clearance seems to be better than the single exit. I'm getting videos of each setup so will post up a rough comparison. Shame couldn't get the cobalt to fit, but might keep it and try again. I'll update again when it's back on the ground and in one piece!
Post by scottydugg on Mar 19, 2020 14:17:39 GMT
With the car back on the ground I took it to Autotec in Port Glasgow for the alignment. I asked for the fast road setup listed on BOFI, which I think is the standard settings after some research. PSX_20200310_172853 by Scott Reid, on Flickr IMG_20200306_171057 by Scott Reid, on Flickr The rear camber is the best we could get, since one of my HSD's is seized at a slightly different height, not ideal but fine for now. Fitted a 4 point harness I've had sitting about for a while, still retain the standard seatbelt, these are easily removed from the bottom and kept behind the seat, so I don't need to faff fitting it to the roll bar everytime I want to use them. They're not to bad to use in a daily driver in all fairness, but I've not gone on any massivly long drives yet. PSX_20200310_173115 by Scott Reid, on Flickr Lastly, took part in my first autosolo, thoroughly enjoyed it (despite finishing near the back of the field) I'll be booking up for the next event whenever that is. I'll need to try some different setups/tyre pressures as running the road setup resulted in massive understeer. PSX_20200316_140432 by Scott Reid, on Flickr Quick snap of some of the cars there that day, the black 5 in front of mine was the overall Autosolo winner that day, it's running a supercharger (maybe one day!) PSX_20200314_184238 by Scott Reid, on Flickr
Post by mrwallace on Mar 20, 2020 12:56:55 GMT
Good progress and nice one on the first Autosolo, very popular with the 5's and I'm sure just as addictive as the sprints/hillclimbs.
Looking at your alignment I'd suggest some toe out up front as that will sharpen the steering response and changing to at least -2deg negative camber on the front too, that will help your understeer.
Hopefully we all don't have to wait too long for some more competitive stuff.... but this gives you time to finich the engine build!
Post by scottydugg on Mar 24, 2020 14:33:04 GMT
Good progress and nice one on the first Autosolo, very popular with the 5's and I'm sure just as addictive as the sprints/hillclimbs. Looking at your alignment I'd suggest some toe out up front as that will sharpen the steering response and changing to at least -2deg negative camber on the front too, that will help your understeer. Hopefully we all don't have to wait too long for some more competitive stuff.... but this gives you time to finich the engine build! The Autosolo was great fun, itching to try another but who knows when that'll be. I spent some time yesterday reading through your progress thread on the other site, the cars come a long way since the last time I saw it. Be interested to pick your brain about A9/Knockhill track days etc. Engine rebuild has stalled but I'll get back to it this year at some stage, depends how long I'm stuck at home for!
Post by suggs84 on Jun 11, 2020 12:19:04 GMT
Absolutely epic transformation from when you first got it, great work!
