Post by apextwin on May 22, 2018 7:36:00 GMT
Nice work. Glad its sorted. My shifter arrived the other day might get it fitted tomorrow. You happy with the shift now ? Big improvement?
Post by howardb66 on May 22, 2018 8:35:56 GMT
My shifter arrived the other day might get it fitted tomorrow. You happy with the shift now ? Big improvement? Yes, feels more positive. Off to Prescott Saturday.
Post by howardb66 on Jun 20, 2018 11:52:19 GMT
Post by Horney on Jun 20, 2018 12:15:56 GMT
Happy with how you got on at Abingdon? Was a great weekend.
Post by howardb66 on Jun 25, 2018 14:53:50 GMT
Happy with how you got on at Abingdon? Was a great weekend. Came 2nd in the CM class by 0.02 sec. I was abit slow on Abington but nailed it on Bentley when I sussed out that most people were braking at the turn boards which were too early IMHO. Time was 106.66 before the handicap was applied.
Post by howardb66 on Jul 28, 2018 19:17:16 GMT
Good day at Combe today & the Europcar parts Brembo discs worked well along with the shaved RS3s.
Came 2nd in CM class with a 65.03 after HC applied.
Post by Horney on Jul 28, 2018 19:44:33 GMT
Nice work!
Post by howardb66 on Oct 2, 2018 7:53:23 GMT
Went for a bit of a blast Sunday & discovered the clutch slipping in higher gears. That’s a real pain in the rear canoe as I’m out at Goodwood on the 6th October & was hoping to do well as it’s one of my favorite tracks. So, a call to Skuzzle as soon as they open Monday morning & Mark confirms the have the bits in stock, 180 miles later & the bits are back home waiting to be fitted...
Made a start last night- exhaust off, ppf off, speedo drive disconnected & rev switch, prop shaft off, gear linkage off.
It was pretty oily down there & the prime suspect is the rear crank oil seal, luckily one was ordered for today.
Post by howardb66 on Oct 7, 2018 11:35:16 GMT
Epic week working on the car & going to work too.... Clutch & Flywheel went on easily once everything was off.... Fitted IL Motorsport engine mounts with engine (& SC) in situ but gearbox off- complete PITA but doable. Had to reweld a couple of exhaust mounts & replaced the rear crank oil seal & seems to be ok. Finished 8.45 pm Friday night, just in time to go to Goodwood for the sprint. Came 2nd & crunched the car a bit but nothing that can’t be repaired.
Post by howardb66 on Oct 8, 2018 16:14:05 GMT
So, arriving from Ebay- Bonnet, Bumper, Splitter, headlight & front wing.
Post by sandys on Oct 8, 2018 19:30:00 GMT
Busy week for you, some dedication there, I struggle to find the time for mine, hopefully got it sorted now though to have a play with you guys at Combe.
Post by apextwin on Oct 9, 2018 8:25:00 GMT
Saw the pics FB! Glad its sortable fairly easily I hope. Great circuit. well done on second place. Long off season ahead for me now. Plenty of bits to sort over winter. Might do the Leaders championship next season.
Post by howardb66 on Oct 9, 2018 17:42:36 GMT
Thanks guys, I should’ve won which would’ve sewn up the championship. Got the bits today but am busy with work till Sunday afternoon but everything should just bolt on right?
Post by sandys on Oct 9, 2018 18:56:09 GMT
What do you need points wise against Roger to sew it up at Combe?
Post by howardb66 on Oct 9, 2018 19:17:45 GMT
I need to win.....
