ooh it's update time, as I've been failing massively and not updating this thread.
well I threw the diff back in the car which is a crappy job as it weighs a tonne but it all went smoothly so no dramas. With the diff in for hopefully the last time I started on making the mock up axle. The MX5 axle is 24mm in diameter and the Audi axle is 32mm in diameter but has a 26mm bore so I was able to slide one inside the other. To get the axles to centre properly I plasma cut 4 pieces of steel that had a step in them to align and centre the 2 axle halves. So I threw the car on the ground set the inner joint so that it was about in the centre of its travel and then chucked a couple of tac welds on it. I unbolted the inner joint but guess what the outer joint had seized in place so I had to use the axle pusher plate thing that I made before
With the axle out of the hub I blasted it with the MIG welder and then once it had cooled down I pulled the axle apart to get measurements so I can get a quote and to get it ready to ship it off when I need to.
I was originally concerned that the axle would be substantially weaker at the MX5 CV joint due to its diameter but the Audi inner CV is only slightly larger in diameter so it shouldn't be a problem. Anyway with the axles sorted and out of the way I decided to finish the mounting the top radiator mounts.:
They're not the prettiest radiator mounts I've ever made but they do the job and the radiator is firmly held in place so that another job done. Annoyingly the mounts now clash on the underside of the bonnet so I'll have to remove some metal from the underside of the bonnet to get it fit and close nicely. Oh well gives me an excuse to add some lightness.
My custom clutch line and the stupidly overpriced circlip arrived so first up I threw them in the car
So the line connects into the back of the clutch master in the footwell then runs over the trans tunnel and through a grommet on the passenger side
The line is the perfect length and fits nicely, I may twist the line slightly so that it sits nicer but other than that its all good. Last thing to do on the clutch is find a reservoir and run a line to the master. After that I figured I'd go back to the radiator and finish up the cooling system. Normally on an E46 the coolant reservoir bolt to the radiator and has a bunch of connectors on the bottom for various coolant channels (Tee off the top rad hose, heater matrix return, block return, etc) the problem is that it won't fit and its plastic so I can't modify it. The M3's have a different setup with a separate coolant reservoir so I figured I'd do something similar.
I've had a random piece of 90mm aluminium tube for about 6 years, no idea why I bought it or what is was supposed to be for so I decided to use it on this project. I ordered a radiator neck and then when it arrived I started fabricating a reservoir. I plasma cut a top plate and welded the water neck into it then tac welded the top to the tube then cut the tube to length
I welded the bottom plate onto it and then welded the brackets onto it
I still need to weld in the fittings for the various in and outs but it looks pretty good if I do say so myself. I've never considered myself much of an aluminum welder as it's not something I do very often but I'm happy with that. So I positioned the reservoir far enough back that I could make it tall enough to make it the highest point in the cooling system to hopefully simplify the coolant bleeding process (Tailgate McNoIndicate make prarrie canoe cooling systems). I'll probably run the overflow to either the OEM Mazda overflow tank or I'll just leave it disconnected Nissan style
next up was the exhaust and I actually did do some exhaust work this time
That right there is 83 welds that need welding, each weld is 239mm long so that is 19.8M of weld that also needs back purging. That also doesn't include welding on the exhaust tip as I haven't decided exactly what I'm going with it yet.
I decided to chuck the tail pipe out the opposite side to what is standard for a couple of reasons:
1. I look to screw with people and it always confuses MX5 people when they notice its on the wrong side (did the same on my MK1)
2. It's a little nod to the Tailgate McNoIndicate as they all come out on this side
I'll probably weld some sort of exhaust tip on it at some point as 3 inch looks kind of small with the super aggressive bumper cut I've got on the car. I'll also change the ultra racing rear brace for a custom one with the a jacking point on it as well.
I've got a couple of days off work coming up so my plane is to get the intercooler piping done, then pull the engine out, weld the oil drain into the sump, paint the bay, finish the manifold welding and then start final assembly.
I've sent off the prop to be shortened and I'll be ordering axles this week so once that is all done that should be all the welding and everything mechanical out of the way. Hopefully in July I can get the ECU ordered and can start wiring. My goal is get the car drivable before the end of July but we will see how that goes. There will be some further bits that will need doing after but they can wait until I've recovered some funds
So after 83 welds on exhaust I decided that I hadn't got my fill of welding pie cuts so I did some more. 48 more welds to be exact
Nothing says racecar like pie cut intercooler pipes! So In reality I decided to pie cut the intercooler as it gives me far more flexibility than using an intercooler kit or mandrel bends and a length of 3 inch aluminium pipe is far cheaper than even a cheap ebay spec intercooler pipe kit. The hot/pre intercooler side is nice and short nd I was able to make it a single piece. The cold/Post intercooler side had to be 2 pieces it would not of been possible to fit it without either dropping the engine or removing the alternator which would not have been ideal.
I still need to weld in a port for the Idle control valve but I need to order the fitting so I'll do that when it arrives. I'm not going to run any kind of dump/blow off valve initially, however once I start to wind up the boot I'll chuck one in there somewhere.
I pulled the engine out of the car, removed the oil sump and welded a return fitting for the turbo oil drain (this was an absolute Canoe to do, between it being cast aluminium and having 20 years of oil absorbed into it, it didn't want to weld nicely); I'm still not entirely sure how well this drain setup will work but I can always revise it and switch to a scavenge pump later down the line. With that out of the way I painted the engine bay, front subframe, gearbox crossmember, prop bearing mounts and engine mounts. I also finished welding and then wrapped the manifold and installed it onto the engine prior to putting it back in the car as it would be near impossible to do otherwise. I threw a standard clutch and flywheel onto the engine for now as I plan on upgrading this later. I was originally gonna switch to a basic solid flywheel and new OEM rated clutch but it seemed as waste as I'd need to upgrade once I start adding more boost so I opted to run a stock one for now. I also gave it a bit of a clean off as it was covered in dust and crap.
Next up I threw some Aerocatch bonnet pins in as I need a way to hold the bonnet down now that the normal latch is gone. With all of the drilling and grinding done and bay blasted out with compressed air to get rid of any dust I threw the engine in for what I hope is the final time. I also threw the gearbox on and bolted that up with some temporary bolts (I need to order the genuine bolts).
So this week I hope to get most of the final assembly done and to finish off the last little bits on the list:
Fully weld wastegate pipe
Wrap wastegate and downpipe
De-Power steering rack/Weld pinion
Replace outer tie rod ends on steering rack
Wire up engine with Tailgate McNoIndicate harness and modify to work with existing Mazda harness
Change all fluids/Service engine, gearbox and diff
Install ABS sensor in front wheel hub to use for speedo
Wire up SGI-100BT to correct tacho signal and generate speedo signal for OEM gauge cluster
I've sent off the prop to be shortened already so that should be back in the next 1-2weeks and I've ordered the new driveshafts so they should be here sometime next month if all goes well.
