Post by Zed. on Jul 22, 2021 15:49:06 GMT
random bored S hitposting time, been playing with gearing calculators comparing different gearboxes (5 & 6 speed Mk1 & mk2) so thought I'd share. 4.3:1 diff. 4.1:1 diff. 3.9:1 diff. 3.6:1 diff. can see the 5speed & 4.3:1 carries similar 1-5 gear speeds as a 6speed & 3.6:1 but the 6th gear works out as a motorway / overdrive / cruise gear. added calculations for the 3.3:1 fd, using different tyre sizes (195, 205 & 215 x 50 x 15") Fast enough? wonder how stale a 5 is @ 180mph also, if you're a masochist.... this is the 4.778:1 (Kia Sportage front diff) gearspeeds. adding a 5.38:1 ratio into the mix for S hItZ&giggles looks like 4,000rpm is... 60mph anyway, the calculator I've used is zealautowerks.com/transcalc.phpan although it's a Honda biased webpage the ratio's & tyre sizes / engine speeds are user-defined so universal Rich.
Post by wannabe on Jul 23, 2021 1:23:31 GMT
Good find 8.5k on the Kia diff max RPM? lol
Post by Zed. on Jul 23, 2021 8:49:12 GMT
8.5k on the Kia diff max RPM? lol wishfull thinking although doubtfull in top Rich.
Post by atlex on Jul 23, 2021 13:23:43 GMT
Post by Zed. on Jul 23, 2021 13:26:56 GMT
I 'normally' use the FM calculator but this one is easier to compare different ratios / tyre sizes & also different engine speeds Rich.
Post by sandys on Jul 23, 2021 15:16:57 GMT
Post by Zed. on Jul 23, 2021 15:31:38 GMT
ha. will find time to play Rich.
Post by sandys on Jul 23, 2021 15:58:36 GMT
Yup I used it to simulate my improvements for different mods at combe using my current known performance as a baseline and surprisingly it wasn't miles off when I trialed the NA/NB 3.99 and 4.44 ratios in my car.
Post by Zed. on Aug 4, 2022 21:05:21 GMT
just adding into this thread, digging in the shed and removed some speedo-drives from dead mk1 5speed gearboxes... purple 22 teeth. red 23 teeth. Rich.
Post by Zed. on Nov 1, 2022 10:31:28 GMT
Origonal post edited & updated with 5.38:1 ratio chart added Rich.
Post by Zed. on Nov 3, 2022 14:18:27 GMT
Origonal post edited & updated with 3.3:1 ratio chart added Rich.
Post by batou on Nov 3, 2022 17:51:40 GMT
Quite a mix of max rpm choices in the additions, is this intentional? Makes it a little difficult to compare the gear speeds but I guess if you're fitting a 5:38:1 you'd be mad enough to run over 8k rpm 😂
Post by Zed. on Nov 8, 2022 20:04:23 GMT
I guess if you're fitting a 5:38:1 you'd be mad enough to run over 8k rpm 😂 what ya sayin? waiting on delivery..... still waiting 9 days now & bofi say "ships in under 10 working days' on their website - should be here soon then Rich.
Post by batou on Nov 9, 2022 19:36:06 GMT
I guess if you're fitting a 5:38:1 you'd be mad enough to run over 8k rpm 😂 what ya sayin? waiting on delivery..... still waiting 9 days now & bofi say "ships in under 10 working days' on their website - should be here soon then Rich. They are usually pretty damn good but suppliers obvs can let them down, I ordered erm, *cough*, another ECU that said ships in 5-10 working days... its been 4 and it got dispatched today so you get lucky sometimes
