Post by boggissimo on Sept 18, 2023 12:49:21 GMT
How it started: How it's going:
Post by boggissimo on Sept 18, 2023 12:50:39 GMT
Had lots of fun at the targa rally on Saturday, but a bit of trouble with the sump guard!
Post by dadbif on Sept 18, 2023 20:34:50 GMT
Sold my mk3, the hunt for an original unmolested mk1 begins…,
Post by boggissimo on Sept 20, 2023 8:30:27 GMT
A few shots from the targa rally
Post by boggissimo on Sept 21, 2023 9:22:55 GMT
And a video
Post by wannabe on Sept 22, 2023 11:19:52 GMT
That looks like a lot of fun but not exactly good in terms of mechanical sympathy... lol
Post by boggissimo on Sept 25, 2023 8:34:06 GMT
That looks like a lot of fun but not exactly good in terms of mechanical sympathy... lol Yeah it was pretty brutal. I've only bothered to upload a video of the one test where the sump guard stayed attached, as the others are marred by the metallic clanging of it banging against everything as it hangs on by one bolt!
Post by atlex on Sept 25, 2023 17:01:14 GMT
I'd love to do a similar rally but I think a slightly lowered 4x4 would be far more sensible XD
Post by dickie on Sept 25, 2023 17:32:21 GMT
Hi Folks I filled the ITB Mongrel with fuel today I have done a personnel best in the car I actually managed to do 180 Miles on the previous tank full. Thats a 50 mile range increase Whoopee !!! Good job its only used as a fun car ! It is still a bit rich in some areas of the map though
My £750 Volvo V70 D5 will do 600 miles per tank full. My CBR 600 does about 125 to 130 on a tank full.
Post by boggissimo on Sept 26, 2023 8:43:39 GMT
I'd love to do a similar rally but I think a slightly lowered 4x4 would be far more sensible XD 2WD only on targas. They run under road rally regulations, though you wouldn't know it from some of the vehicles!
Post by atlex on Sept 26, 2023 20:04:06 GMT
could imagine a datsun or mazda b series rwd 'truck' doing quite well.
Post by boggissimo on Oct 3, 2023 13:19:18 GMT
Busy weekend, Goodwood sprint on Saturday, then Tour of Kent on Sunday
Post by boggissimo on Oct 4, 2023 8:06:39 GMT
Started getting bits off the engine to do the valve stem oil seals. There was a LOT of oil behind the timing covers, so will need to do the cam seals too.
Post by boggissimo on Oct 9, 2023 8:23:36 GMT
Tour of Kent at high speed
Post by dickie on Oct 10, 2023 5:48:06 GMT
Hi Folks, On Sunday we took the Mongrel out and about in cornwall with the OC. I stopped for fuel after a 30 mile drive to the start of the run, went to top up with petrolonly to find the car refused to start with all the symptons of a dead battery, I plugged in the laptop to check the voltage which was showing just over 12.5 volts tried to crank and it dropped down to 7.2 volts on attempting cranking then back up to 12.5 volts when I stopped cranking. Put a borrowed jump pack onto it and we got a start, Voltage with engine running showing 13.5 volts so the alternator is working. As the car cranks and starts fine when its cold I think the starter motor is getting knackered with a very high hot resistance. I will be fitting a MK2.5 starter motor this week to see if the problem goes away.
