Post by atlex on Jul 21, 2021 11:40:26 GMT
Yes, just wired into the stock power supply. I used some ali bar stock and countersunk m8? bolts and nuts - I think it took some extra m8 nuts to "shim" the fan up to the back of the rad..
Post by scottydugg on Jul 21, 2021 11:51:06 GMT
Yes, just wired into the stock power supply. I used some ali bar stock and countersunk m8? bolts and nuts - I think it took some extra m8 nuts to "shim" the fan up to the back of the rad.. Ok thank, I'm going to go through rad with the mounting, but not the cable tie option, using these HERE. All my lower bosses have snapped bolts as the rad was second hand, if it gets damaged I'll replace in the future. Thanks for you help, I'll get the fan ordered.
Post by dadbif on Jul 21, 2021 21:05:43 GMT
One mod I have done previously is to wire in an override switch, so if for instance the sensor controlling the fan failed I could switch it on manually, or you could control an additional fan thus…
Post by scottydugg on Jul 22, 2021 8:21:39 GMT
One mod I have done previously is to wire in an override switch, so if for instance the sensor controlling the fan failed I could switch it on manually, or you could control an additional fan thus… I've got the A/C circuit, but removed the A/C button, I like your thinking. Maybe keep the small 9" SPAL unit and hook it up that way? interesting.
Post by howardb66 on Jul 22, 2021 11:27:33 GMT
One mod I have done previously is to wire in an override switch, so if for instance the sensor controlling the fan failed I could switch it on manually, or you could control an additional fan thus… I've got the A/C circuit, but removed the A/C button, I like your thinking. Maybe keep the small 9" SPAL unit and hook it up that way? interesting. Do it. I was having a few heat issues, no with the over ride they have completely gone away.
Post by scottydugg on Jul 22, 2021 14:20:29 GMT
I've got the A/C circuit, but removed the A/C button, I like your thinking. Maybe keep the small 9" SPAL unit and hook it up that way? interesting. Do it. I was having a few heat issues, no with the over ride they have completely gone away. Is that supercharged or after going turbo?
Post by dadbif on Jul 23, 2021 7:12:25 GMT
I have a supercharger, standard rad and fan, no overheating.
Post by howardb66 on Jul 23, 2021 9:00:13 GMT
Do it. I was having a few heat issues, no with the over ride they have completely gone away. Is that supercharged or after going turbo? It was just a few weeks ago & really wished I’d done it earlier. The SC produced a lot of heat & after a sprint or hillclimb run the bonnet was almost too hot to touch. On the road it wasn’t much of an issue as you just can’t drive as fast but if you’re planning on doing trackdays or any sort of competition I would definitely recommend it. You’ve got the fans & old A/C wiring so should’n’t be too tricky. 👍🏻
Post by scottydugg on Jul 23, 2021 10:11:22 GMT
Is that supercharged or after going turbo? It was just a few weeks ago & really wished I’d done it earlier. The SC produced a lot of heat & after a sprint or hillclimb run the bonnet was almost too hot to touch. On the road it wasn’t much of an issue as you just can’t drive as fast but if you’re planning on doing trackdays or any sort of competition I would definitely recommend it. You’ve got the fans & old A/C wiring so should’n’t be too tricky. 👍🏻 Thanks Howard, quick bit of reading up and all you need is to connect 2 wires behind the glovebox and and an A/C fan can be used for additional cooling, a lot simpler than I thought (guide HERE shown in post 2). I think I'll go with the 9" SPAL on that circuit, maybe enough room as well for an oil cooler should I go down that route.
Post by scottydugg on Jul 26, 2021 12:21:00 GMT
After the questions above, went and bought a 12" SPAL unit which has now arrived along with a top entry intercooler (Core sixe:330x280x76mm, 2.5" inlets), which I thought might be a tad on the big side but I've seen others use larger coolers. Spent some more time cutting out and refining the 3 apertures for the gauge pods, best advice to anyone doing this would be cut a little and check a lot, wear a face mask as well. IMG_20210725_170410 by Scott Reid, on Flickr Then test fitted the pods, they've only had a couple coats of gloss black, still need some lacquer. IMG_20210725_170439 by Scott Reid, on Flickr Plan is to run from the drivers side: AEM UEGO Wideband, Stack Boost Gauge and Coolant Temp Gauge. Removed the Wideband from the vent it was fitted to, made up a bracket from some 20x2mm Aluminium. This one only required a single bend, but the Stack gauges will need something more in line with the RevLimiter guide. I might add some spreader plates as per the guide also. IMG_20210725_183855 by Scott Reid, on Flickr Final step was to notch it to allow access for the relevant plugs. Not the neatest but it'll do for what I had available. IMG_20210725_190959 by Scott Reid, on Flickr 20mm is slightly too wide for the Stack gauges, but I'll just notch them in the relevant places. I think I'm going to run my volt gauge underneath the radio along with my clutch switch cut off (launch control), potentially a second switch that kills the 12V feed to the Wideband (a la Bilbo , did you do this in the end?) so as to not overheat the wideband sensor if not running the car but sat with the ignition on. Hopefully more to come next weekend.
Post by Bilbo on Aug 5, 2021 13:06:18 GMT
I did do that yes, works very nicely. Just a simple flick switch intercepting the 12v feed wire. Very simple!
Post by scottydugg on Aug 9, 2021 10:22:57 GMT
So continuing on from above, I've spent more time on the gauge pods, mocked up some brackets for the Stack gauges, only difference between the 2 is the clearance required for the connections on the reverse side. Here's the temp gauge from the reverse: IMG_20210807_190330 by Scott Reid, on Flickr Since gone on to stick some spreader pads to the reverse of the crash pad, for where the brackets will come into contact. I couldn't find direct replacement nuts to fit the Stack gauges, so I had to buy a thread gauge and then a tap to retap some spare nuts I had laying around. They're an odd size of M4x0.8. Whilst I waited for the adhesive to dry, I thought I'd do a dry mock up of the supercharger and all the brackets/hardware. It's lucky I did, the hardware supplied by Garage42 would work fine if I had the complete kit from them, but I'm using an inlet and outlet from a guy who made a small batch on Facebook. So the bolts supplied need replaced for some cap screws, not an issue but a good way to spend some time over a Sunday afternoon. I've also got the Garage 42 tensioner that Ed made a batch of, now most folk use idler pulleys for these, but got some transit alternator pulleys from the same guy that sold me the inlet/outlet. They'll just need some spacers for the tensioner to clear them as they're quite a bit deeper than the mx5 tensioner pulleys. IMG_20210808_184429 by Scott Reid, on Flickr Ordered up everything I think I'll need so will try a proper mock up when it arrives. Hopefully get these gauges in soon, then I can get the ECU fitted.
Post by Zed. on Aug 9, 2021 12:41:07 GMT
I couldn't find direct replacement nuts to fit the Stack gauges, so I had to buy a thread gauge and then a tap to retap some spare nuts I had laying around. They're an odd size of M4x0.8. *might* have spare bracket & nuts Rich.
Post by scottydugg on Aug 9, 2021 13:08:30 GMT
I couldn't find direct replacement nuts to fit the Stack gauges, so I had to buy a thread gauge and then a tap to retap some spare nuts I had laying around. They're an odd size of M4x0.8. *might* have spare bracket & nuts Rich. I'm ok for brackets, but if you don't need the nuts let me know please, re-tapped nuts are fine for doubling up, but I'd rather use genuine for pulling the gauge pod into position.
Post by scottydugg on Aug 11, 2021 13:15:15 GMT
Bought a TDR manifold blanket from Moss, reading some of the reviews it seems an absolute no brainer, when trying not to cook the charger.
Not the cheapest item, but hopefully it'll pay for itself in the long run.
