Post by Whistler on Nov 4, 2024 17:17:05 GMT
Going hall effect with a front cam sensor is clever and frankly superior. However keep a close close eye on the Maruha adjustables. The surface coating of mine wore out fast. Toda Adjustables are superior (lighter, don't appear to wear) but don't support running a hall effect sensor without some physical modification. What cambelt will you run ? Yeah - I have been warned about Maruha cam gears, but didn't want to modify a set of new Todas. I run Toda on my daily drive and they're not showing any signs of wear as yet. I have a Gates racing cambelt installed at the moment, so I'll leave that in place for now and keep an eye on things when I get the car running.
Post by Whistler on Nov 4, 2024 17:20:21 GMT
Chinese Diesel heater arrived this afternoon. Despite the royally Canoeed box, it arrived in one piece. I just need to buy a 'through hull' exhaust port and power supply and I'll get it all plumbed in.
Post by atlex on Nov 4, 2024 20:46:19 GMT
Going hall effect with a front cam sensor is clever and frankly superior. However keep a close close eye on the Maruha adjustables. The surface coating of mine wore out fast. Toda Adjustables are superior (lighter, don't appear to wear) but don't support running a hall effect sensor without some physical modification. What cambelt will you run ? Yeah - I have been warned about Maruha cam gears, but didn't want to modify a set of new Todas. I run Toda on my daily drive and they're not showing any signs of wear as yet. I have a Gates racing cambelt installed at the moment, so I'll leave that in place for now and keep an eye on things when I get the car running. gates racing + maruha was my combo that wore hope it works out!
Post by Whistler on Nov 4, 2024 22:49:42 GMT
Yeah - I have been warned about Maruha cam gears, but didn't want to modify a set of new Todas. I run Toda on my daily drive and they're not showing any signs of wear as yet. I have a Gates racing cambelt installed at the moment, so I'll leave that in place for now and keep an eye on things when I get the car running. gates racing + maruha was my combo that wore hope it works out! I'll keep an eye on them and see how it goes. Out of interest, how many miles did you do before you noticed the wear? I can always use the OEM gears as a standby if things look like they're going to get terminal.
Post by atlex on Nov 5, 2024 12:08:53 GMT
gates racing + maruha was my combo that wore hope it works out! I'll keep an eye on them and see how it goes. Out of interest, how many miles did you do before you noticed the wear? I can always use the OEM gears as a standby if things look like they're going to get terminal. Less than 100kms. :-( I reused my old gates blue belt, which may or may not have been a factor. with an open cam pulley area it should be readily apparent.
Post by Whistler on Nov 5, 2024 15:53:32 GMT
This arrived today. It came up cheap, and as I needed a housing for my 3.6 Torsen I thought I might as well grab it.
Post by atlex on Nov 6, 2024 20:19:29 GMT
Post by Whistler on Nov 7, 2024 8:18:12 GMT
That's pretty poor! Let's see if mine do the same.
Post by atlex on Nov 7, 2024 10:06:30 GMT
That's pretty poor! Let's see if mine do the same. FYI Maruha did nothing as a result. I now run toda gear and toda belt, and checked after 1000km there was barely any wear.
Post by Whistler on Nov 10, 2024 9:54:32 GMT
No progress on the car this week, but the garage is coming along. Next step - push the car over to this side of the garage so I can finish insulating the roof on the other side.
