Post by wannabe on Jun 10, 2022 2:49:59 GMT
Brimmed it from below the 'E' mark on the fuel gauge and wondered why 35 litres is somehow a full tank when (IIRC??) the tank is 50 litres / 10 gallons... I can only presume that the fuel sender gauge is wonky... ,,, but I guess that at least I will have about 3 gallons / 90 miles left as 'reserve' when it's on the Empty mark! lol It does appear to have done almost 32mpg on that basis, though, which is pretty good going from what I can tell. (They don't ever seem to get above that, do they?? Or perhaps it's something to do with driving style... haha)
Post by atlex on Jun 10, 2022 14:25:28 GMT
White: Took my ctek to the body shop to help recover the battery. Ordered a lifepo4 replacement also. Started her. she idles as usual. Let her warm up and then shut her off again. She's filthy from having been in a bodyshop for 3 months. But the bumper is going on soon. The new paint is beautiful.
Blue: She's getting the new skuzzle clutch on now. old flywheel was a 1.6 ILM 4KG, new one is an XACT 1.8 4.2KG.
Silver: (not really an mx5, but she's a Roadster never the less) I've finally worked my way to the 50 degree cam angle tables. the tables were with a 'dyno tuned' setup and honestly I don't think the dyno tuning was that good, it's waaaay too rich on decel. I can take 10-20% fuel out most of the lower cells and it still won't go over 14.7 AFR. New front steering rack arms have turned up to go with the front steering arm ball joints/tie rod ends. The existing ones are rusted together quite strongly.
Post by wannabe on Jun 11, 2022 0:05:37 GMT
it's waaaay too rich on decel. I can take 10-20% fuel out most of the lower cells and it still won't go over 14.7 AFR. Dumb question alert! I thought deceleration cut the fuel totally on modern engines...?? (unless someone's fitted a pop-pop-bang-bang aftermarket map that dumps a load of fuel in?)
Post by atlex on Jun 11, 2022 11:13:40 GMT
it's waaaay too rich on decel. I can take 10-20% fuel out most of the lower cells and it still won't go over 14.7 AFR. Dumb question alert! I thought deceleration cut the fuel totally on modern engines...?? (unless someone's fitted a pop-pop-bang-bang aftermarket map that dumps a load of fuel in?) Not a stupid question at all. at 0% TPS and very low manifold pressures a modern engine is effectively not running the injectors. this is actually what happens on my ECU. I literally watch this happen via the AFR because when I take the foot completely off the throttle the AFRs spike (18, 20..) and then stop reading. What's happened is the MAP sensor has detected the dropping pressure and so reduced the fueling in line as the air supply tails off, it then richens up as you touch the throttle or reach the idle zone. And this is of course completely safe, the engine isn't trying to produce a dyno chart social media post in this condition. You want it to be at least 'slightly lean' in this area. Realisitically you could also cut fuel at low TPS in this area too, but this area is also used for 'gradual decel' or 'very mild cruise' so you don't actually want a complete cut-off at over 1% TPS., you still want the engine to add some power on a flat or slight incline. There's a lot of 'decel' area above 0% TPS that is sort of like 'slowing cruise' or similar. You've got 1-3% TPS and you're say, just going down a hill but don't want to brake completely. the air pressure inside the manifold is like 30% atmospheric and the airflow into the engine is miniscule because the TPS is nearly shut. You should be aiming for 'at least 14.7' and maybe settle on something closer to 15:1 or 16:1 AFR. This is like 1% the airflow of a loaded WOT engine, so the engine is just cycling air rather than trying to make power / speed up. Lean is completely safe in this area. If it's running richer than 14:7 at this point it's effectively throwing fuel away for no reason. In my case I was seeing 12:1 or 13:1 on decel.
Post by dadbif on Jun 11, 2022 21:33:57 GMT
You can select fuel cut on deceleration on a MS, with various selectable parameters
Post by boggissimo on Jun 13, 2022 12:15:03 GMT
Went to take my son out for a spin in the Mazda on Friday, and it wouldn't start. Completely flat battery. That'll teach me to leave it idle for a month! Connected my battery booster and it started up first time.
Then took my daughter out in the sunshine, drove for about 15 mins to a shop, and when we got back in to come home the battery still didn't have enough juice to start it (I had brought the booster so no big deal). Will see if it's a failing battery or just needed a bit more charging, but I've got a sprint on Saturday and a trackday next Monday, so don't want to faff about with it too much.
Post by scottydugg on Jun 13, 2022 12:36:56 GMT
Went to take my son out for a spin in the Mazda on Friday, and it wouldn't start. Completely flat battery. That'll teach me to leave it idle for a month! Connected my battery booster and it started up first time. Then took my daughter out in the sunshine, drove for about 15 mins to a shop, and when we got back in to come home the battery still didn't have enough juice to start it (I had brought the booster so no big deal). Will see if it's a failing battery or just needed a bit more charging, but I've got a sprint on Saturday and a trackday next Monday, so don't want to faff about with it too much. If it's a standard gel battery, they don't like to sit for more than a week apparently (after reading the doc. that came with my new one), I've fitted one of those negative terminal isolators to see if that helps as per recommendation. 30 minute run should see you right, hopefully that sorts it for the weekend!
Post by boggissimo on Jun 13, 2022 15:19:05 GMT
Went to take my son out for a spin in the Mazda on Friday, and it wouldn't start. Completely flat battery. That'll teach me to leave it idle for a month! Connected my battery booster and it started up first time. Then took my daughter out in the sunshine, drove for about 15 mins to a shop, and when we got back in to come home the battery still didn't have enough juice to start it (I had brought the booster so no big deal). Will see if it's a failing battery or just needed a bit more charging, but I've got a sprint on Saturday and a trackday next Monday, so don't want to faff about with it too much. If it's a standard gel battery, they don't like to sit for more than a week apparently (after reading the doc. that came with my new one), I've fitted one of those negative terminal isolators to see if that helps as per recommendation. 30 minute run should see you right, hopefully that sorts it for the weekend! Yeah, I'm sure I've let it sit more than a month before without it draining, so will keep my booster with it until I'm confident again. Suppose I could save some weight with one of those newfangled LiFePo batteries if I do need to change it! #silverlining
Post by Zed. on Jun 13, 2022 17:24:23 GMT
If it's a standard gel battery, they don't like to sit for more than a week apparently (after reading the doc. that came with my new one), I've fitted one of those negative terminal isolators to see if that helps as per recommendation. 30 minute run should see you right, hopefully that sorts it for the weekend! Yeah, I'm sure I've let it sit more than a month before without it draining, so will keep my booster with it until I'm confident again. Suppose I could save some weight with one of those newfangled LiFePo batteries if I do need to change it! #silverlining www.ebay.co.uk/itm/393815536821or without ebays costs... jackwebbmotorsport.co.uk/JWM-PS-20-LiFePO4-BATTERY-BUNDLE-p389182506Rich.
Post by atlex on Jun 13, 2022 18:37:26 GMT
Post by dickie on Jun 15, 2022 19:39:28 GMT
Hi Folks Wossner Piston set back home in the garage. I am glad I put them in my hand baggage as my main case is doing some random flights back from the USA It is not expected to turn up till friday !!
The next stage is the big save up for Custom Crank and Rods.
Cheers Dickie
Post by dickie on Jun 25, 2022 17:25:18 GMT
Hi All,
Having just got back from various travels I did a pre MOT check including making sure the mixture was right at the MOT test engine speeds. I have fitted the new TPS and set that up as well, I then discovered that the TPS plug had an intermittant contact so a new plug and pins are now on order. The only MOT related issue is a blown bulb for the number plate. So I will book the beast in and hope the TPS fault does not appear during the test.
Post by dadbif on Jun 26, 2022 8:12:18 GMT
The MR2 has gone to a new home, just couldn’t get on with it. On the hunt for another 5, having had three MK1’s I feel it’s time for a change. Before I start poking around, whereabouts is rust most prevalent on mk3’s?
Post by thruxton on Jun 26, 2022 10:38:02 GMT
Hi there. Ohhhh, interested to know more about the MR2 experience.
But …. I am a true MK3 convert …. it all had to do with an evening encounter with Horney.
The stars where out the evening was warm ….. No, it was the way that his soft top went up and down, ooo er, you’ll find out. I know, but there it is. Apart from that the MK3 is just such a better car, end of. Forget all the utter bollox about ….. oh but it’s a boat it’s a heavy car. Shut up! It’s not and it’s not.
I’ve had 3 MK3 MX-5 cars. For what it’s worth, if anything, here are some of my thoughts.
I had a 10K miles from new 2015 PRHT 2.0 Sport Tech.. Now very weirdly this just did not do it for me, no. It is said that the gearbox is better than the early ones and the engines are better. In the real world, no there not.
I am back in a 2006 2.0 Sport. Showing 106,000 miles and all is good. Obviously a very fast one …. Because it’s bright red. It has a hard top. Well worth swinging into a deal. Have you seen the prices of these recently? Flippin heck! I wish I had ten in the shed.
No rust on mine. They do rust, like almost any MX-5 does. Just be sensible when looking at them.
Now the prices of ones you would WANT to own are for sure going up. Maybe it’s summer time uplift? But honestly. I think people are waking up to the value of what you get for your money. I would not buy a 1.8. No point when the 2.0 is so much better and sod all dearer.
If like me you want upgrades which mine has, then the market is awash with stuff. Apart from all the wheels, tyres, brake kits, suspension the best “bang for you buck” has to be the 225Bhp ITB and camshaft blah blah package from BBR. Not cheap, but not dear and the difference is really night and day.
If you are at the track day let’s catch up.
Regards. Rich.
Post by dadbif on Jun 26, 2022 13:48:09 GMT
The MR2 was rust free and had an excellent ding free body + hardtop, but although it was quite quick and nimble, just like a 5, I always felt as if I was driving in a skip! The waistline of the car was high and the interior, despite red leather seats and door inserts, felt a very gloomy place compared to my V special. I also found it harder to get in and out of than the MK1, the main reason I changed…. So, I am in two minds at the moment, the MK3, 2.0ltr with PRHT is very attractive, but a rust free (I know) MK2 would be preferable, better access to engine etc for upgrades. Finding one without bodged sills and with the outriggers fixed will be difficult, but I am in no hurry.
