Post by myothercarsa2cv on Oct 14, 2017 17:16:39 GMT
Continued breaking the car today. I hurt ðŸ˜
Post by melx5 on Nov 2, 2017 7:53:06 GMT
Removed front lip ready for bumper respray next week, well I say removed, I Canoeing had to destroy the bloody thing to get it off, flexible plastic and 20+ year old seized bolts..........................
Twat!!!!!!!!!!!
Post by howardb66 on Nov 2, 2017 9:04:40 GMT
Fitted new brake master cylinder & bled the brakes- twice....
Cleaned the suspension & covered the whole underside in a combination of ACF50 & Waxoil.
MOT passed without advisories, WOOOHOO!!!!
Simon
Post by Simon on Nov 2, 2017 12:24:34 GMT
After about 2 weeks of painfully trying to ignore the fact my steering sounded like a moaning cougar ( in both senses ) finally topped the bastard up with ATF and now quiet not jerky steering can continue
Post by wannabe on Nov 2, 2017 13:18:58 GMT
Checked the oil and water, wiped the windows off, drove it for an hour with the roof down The oil looks to be at Max but the oil pressure is below 1bar on hot idle, so clearly it does need more oil, as that usually brings it back up to 1bar! Bloody thing...
Post by atlex on Nov 2, 2017 13:23:58 GMT
Checked the oil and water, wiped the windows off, drove it The oil looks to be at Max but the oil pressure is below 1bar on hot idle, so clearly it does need more oil! Bloody thing... You sure that's what it means ?
Post by minty on Nov 2, 2017 17:16:46 GMT
Weirdly my r-ltd 'appears' to have a proper moving oil pressure gauge? Didn't think that was a thing on later 5s?
Anyway today fitted winter wheels and hardtop roof liner (I have a spare slightly too small one I will be selling cheap lol)
Just got a fit jass hardtop brackets now - any tips? I assume it requires two people to install it tightly?
Post by wannabe on Nov 2, 2017 22:42:22 GMT
Checked the oil and water, wiped the windows off, drove it The oil looks to be at Max but the oil pressure is below 1bar on hot idle, so clearly it does need more oil! Bloody thing... You sure that's what it means ? That is all it's allowed to be... lol Short Nose Crank means I can't change the oil pump, so it's not allowed to fail!! Pressure does rise with more oil in it, and it does need a service so it's probably a bit thinner as well, so will get it serviced and cross my fingers!
coop
Post by coop on Nov 4, 2017 11:02:26 GMT
Last night I fitted my Raydyot mirrors, still need some adjustment and a little tightening on the pivot point, but they look so much better. Opted for the spun aluminium versions, but they'll be off to be painted soon.
Visibility is prarrie canoee, but will get used to it. Sold as having convex glass, but must've missed the memo on this particular set.
Post by melx5 on Nov 5, 2017 7:11:45 GMT
Last night I fitted my Raydyot mirrors, still need some adjustment and a little tightening on the pivot point, but they look so much better. Opted for the spun aluminium versions, but they'll be off to be painted soon. Visibility is prarrie canoee, but will get used to it. Sold as having convex glass, but must've missed the memo on this particular set. Any pictures of the mirrors fitted? What did you do with the original mirror mount holes?
Post by atlex on Nov 5, 2017 12:20:12 GMT
ACF50'd the sills :-)
coop
Post by coop on Nov 5, 2017 13:00:52 GMT
Last night I fitted my Raydyot mirrors, still need some adjustment and a little tightening on the pivot point, but they look so much better. Opted for the spun aluminium versions, but they'll be off to be painted soon. Visibility is prarrie canoee, but will get used to it. Sold as having convex glass, but must've missed the memo on this particular set. Any pictures of the mirrors fitted? What did you do with the original mirror mount holes? I’ll grab some pictures tomorrow, little time today. They came with mounting plates that use the existing holes, but they were unpainted ali, so ordered some black Jass ones to keep the green and black theme going.
Post by melx5 on Nov 10, 2017 17:26:20 GMT
picked it up from the body shop
Post by melx5 on Nov 10, 2017 17:30:17 GMT
[br Pics not loading from my phone.....
Post by melx5 on Nov 10, 2017 18:31:27 GMT
Front bumper minus holes Wing had a crease and some rust on the arch which has been there since before I owned the car Hardtop now Lotus Cortina white, marmite maybe but I like the contrasting colours
