Post by scottydugg on Jun 1, 2023 15:29:15 GMT
also what's the dwell time ? share your tune and logs :-) Will post them up tonight so you can have a poke about.
Post by scottydugg on Jun 2, 2023 9:11:24 GMT
Will need to post these up tonight, on the drive home the idle was fluctuating the worst it ever has, I don't know what I changed but I think his fuel calculator had been adjusted without it calculating so I've changed it without noticing (Canoe knows), it got dumped in the garage in a huff anyway and went for a curry.
Post by scottydugg on Jun 8, 2023 14:33:46 GMT
Post by boggissimo on Jun 9, 2023 11:26:36 GMT
I can see the files, but know nothing about tuning
Post by scottydugg on Jun 9, 2023 12:18:48 GMT
Appreciate you taking the time to check boggissimo, thank you. I've just posted on the local 5 page I'm going to split it and part out, hard decision but I've got a new house coming in August and our first child in October, so realistically the 5's going to be on the back burner long term. Plus to fix the rust and get it where I'd want it it'd be a grand if not more, which I just don't have the funds/time for. So it'll be replaced with a 5 door short term, another fun car in a few years. If anyone wants any of the parts let me know, I'll do a proper ad this weekend. I'm in Glasgow but I'll be able to post most things I would imagine, would be good to see a forum member get the use of them. I think the rolling shells already been claimed
Post by niklas on Jun 9, 2023 14:06:30 GMT
Cant see the maps from the phone, so cant help you there right now. I kept my five with children. It just spends a lot more time in the garage. Both my kids loves riding in it, just saying
Post by atlex on Jun 9, 2023 14:15:56 GMT
Cant see the maps from the phone, so cant help you there right now. I kept my five with children. It just spends a lot more time in the garage. Both my kids loves riding in it, just saying Same position here <B
Post by atlex on Jun 9, 2023 14:17:19 GMT
Might get a relaxing moment this weekend to look.
Post by atlex on Jun 10, 2023 14:09:19 GMT
Might get a relaxing moment this weekend to look. OK, the mild and relaxing moment has occured (post prandial tune review time) Appears you're running the IAT valve - there's idle control with the PW I think. But as it tries to control the idle the AFR goes super lean because it's letting more air in but it doesn't seem to be controlling the fueling properly. Just watch it cycling the PW for idle and the AFR spiking at the same time, I hope it's obvious. The VE cells where the IACV operation sends it need more VE to compensate for the extra air. add another 10-20% in the cells nearby idle. And then drop in the closed lambda idle to let it manage itself, once that's done. You should aim for a stoich idle - 14.7 afr (or a touch more if you want to reduce the co aka monoxide), but honestly if you just need it to idle nicely for the time being don't be afraid to idle it at 13 afr. That big block/area of '55' needs to be more like '60' or '65' in other words - don't be afraid to tune the cells that are 54 either, the whole point is to get the car to idle correctly when HOT - and THEN do the cold start once the car has spent a night cooling off. Alex
Post by atlex on Jun 10, 2023 14:10:46 GMT
OK that's the 3rd tune I've reviewed today ignoring my own lol.
Post by atlex on Jun 11, 2023 12:51:27 GMT
Also one more thing to add you should make sure your sensors are all calibrated properly :-)
Last note - you bought this tune online ? So it wasn't made by someone with your actual car and mods and everything - who could see your AFRs for each area of the map - consequently you have to treat it all (literally every cell) as a 'nice guess at the time' and get it all correct yourself or with a tuner. It's really no better than a basemap and hopefully no worse either.
I recommend getting it right yourself since it isn't that hard, just keep backups (dated? or just numbered ?) as you go so you can always go back if you catch yourself out.
The VE table is there to inform the ECU of how much fuel the engine generally consumes in that area of the map. You can work out an approximate correction by seeing the AFR figure you get for the cell and dividing it by the target AFR. How this works.. and an example to work out the calculation..
current AFR - 16 target AFR - 14.7 current VE cell number - 55 (current/target) * cell = new cell number
( 16/14.7) * 55 = 60 is your new VE cell number
go forth and fix it yourself!
Post by scottydugg on Jun 12, 2023 8:55:46 GMT
Also one more thing to add you should make sure your sensors are all calibrated properly :-) Last note - you bought this tune online ? So it wasn't made by someone with your actual car and mods and everything - who could see your AFRs for each area of the map - consequently you have to treat it all (literally every cell) as a 'nice guess at the time' and get it all correct yourself or with a tuner. It's really no better than a basemap and hopefully no worse either. I recommend getting it right yourself since it isn't that hard, just keep backups (dated? or just numbered ?) as you go so you can always go back if you catch yourself out. The VE table is there to inform the ECU of how much fuel the engine generally consumes in that area of the map. You can work out an approximate correction by seeing the AFR figure you get for the cell and dividing it by the target AFR. How this works.. and an example to work out the calculation.. current AFR - 16 target AFR - 14.7 current VE cell number - 55 (current/target) * cell = new cell number ( 16/14.7) * 55 = 60 is your new VE cell number go forth and fix it yourself! Morning atlex, thanks for looking through the tune, very much appreciated. It's not a generic tune offline, it's been tuned by the tuner in person over quite a while, a couple visits and was left with him for 3 weeks. I've pretty much decided over the weekend that it's going in bits though - I've already listed a couple bits for sale. Unfortunately I can't justify sinking anymore into it and I don't want it sitting for years till I have time/funds. I'll list a proper ad today, but if anyone wants any bits just let me know, would be good to see a forum member get the use of them.
Post by scottydugg on Aug 8, 2023 11:12:01 GMT
IMG_20230805_132923 by Scott Reid, on Flickr So just over 6 years of ownership, undisclosed amounts of money, lots of time/effort/blood/sweat and swearing. Guy who took it is going to re-shell his turbo mk2 into it supposedly - so it'll go back to being a drifter. Managed to shift 2 thirds of the parts so far which isn't too bad going - not sure what will replace it yet. Sad to see it go in all honesty, keep seeing mx5's going about and get a wee pang of guilt that I've gotten rid and should have maybe stuck with it. Anyway, will probably hang about and see how everyone's projects develop from here.
Post by niklas on Aug 8, 2023 14:13:12 GMT
You'll drive other stuff, get the colors of the grass, get into motorcycles and eventually get back inte some generation of 5.
But then you'll get to modify one again, and thats fun.
Post by scottydugg on Aug 9, 2023 11:33:04 GMT
You'll drive other stuff, get the colors of the grass, get into motorcycles and eventually get back inte some generation of 5. But then you'll get to modify one again, and thats fun. Thanks Niklas, very true it's my third so I'm sure a fourth might be on the cards in the future - although I do feel like trying something different that doesn't rust so much!
