Post by mrwallace on Oct 1, 2020 8:50:02 GMT
Good stuff. How close did they get the corner weights? New coilovers compliant enough on the road then?
I've decided I'm definately upgrading, using the kerbs at a recent trackday on a sprint track I've not done before I found I was bottoming out the shocks.
Post by boggissimo on Oct 1, 2020 8:58:40 GMT
Your car looks so clean!
Post by howardb66 on Oct 1, 2020 10:54:46 GMT
Good stuff. How close did they get the corner weights? New coilovers compliant enough on the road then? I've decided I'm definately upgrading, using the kerbs at a recent trackday on a sprint track I've not done before I found I was bottoming out the shocks. The corner weights were pretty well balanced & weight distribution 50%/50% diagonally. I set the shocks in the middle of the adjustment but the front was too soft so I wound them 5 clicks harder which was too hard so backed off a couple, then another 1 on both fronts & there’s still plenty of adjustment left in them. Am at 12 from full hard. I was a little concerned with the massive increase in spring rates ruining the ride but actually didn’t need to worry- it’s as good if not better than before plus the rears don’t bottom out.
Post by howardb66 on Nov 6, 2020 9:37:24 GMT
A box of bits arrived from BlackCat today. Brilliant service as only ordered Tuesday, just waiting on the manifold & DP from Bofi.
jon
Post by jon on Nov 6, 2020 15:58:42 GMT
Which blower did you go for?
Post by howardb66 on Nov 7, 2020 17:06:43 GMT
Which blower did you go for? Sorry to disappoint, went for the TD04 turbo & am waiting for a G19 manifold+DP to arrive from BOFI.
Post by atlex on Nov 7, 2020 20:57:39 GMT
Which blower did you go for? Sorry to disappoint, went for the TD04 turbo & am waiting for a G19 manifold+DP to arrive from BOFI. Interesting and congrats. Did you get the G19 dipstick oil return also ?
Post by howardb66 on Nov 8, 2020 8:43:31 GMT
Sorry to disappoint, went for the TD04 turbo & am waiting for a G19 manifold+DP to arrive from BOFI. Interesting and congrats. Did you get the G19 dipstick oil return also ? No, going to drill & tap a return directly into the sump.👍🏻
Post by Vindi (Russell) on Nov 13, 2020 11:54:31 GMT
Interesting and congrats. Did you get the G19 dipstick oil return also ? No, going to drill & tap a return directly into the sump.👍🏻 Good to hear, the dipstick route always looked like a cheap bodge. One of the local guys had one & the dipstick kept being pushed out Russell
Post by Zed. on Nov 13, 2020 15:09:54 GMT
the dipstick route always looked like a cheap bodge Glad I'm not the only one that thinks that Rich.
Post by howardb66 on Nov 14, 2020 17:17:36 GMT
Was doing a bit of pre MOT poking around & the sill that I’d meant to repair was looking a bit crusty..... Got busy with the wire brush and the result was pretty bad.
Post by howardb66 on Nov 14, 2020 17:22:44 GMT
A little bit more action with the brush on the angle grinder & the extent of the rot is pretty extensive. Inner, outer & bottom of the wheel arch are completely rusted out. upload/upn823eb2p.jpg/upn823eb2p.jpg] [/url]
Post by howardb66 on Nov 14, 2020 17:29:40 GMT
I can weld a bit but that is way out of my comfort zone. Time to call the cavalry.
Post by howardb66 on Nov 14, 2020 17:38:52 GMT
Should get through the MOT now....
Post by batou on Nov 14, 2020 18:49:46 GMT
Wow, your welding skills improved pretty fast..... I presume thats everything cut out now? Its painful having to do these but feels great when you know they are done mind.
