Post by niklas on Nov 14, 2020 18:54:08 GMT
If anyone is considering a 3j but being wary of my previous post describing the racket it made...
Now that its run in, it's virtually silent everywhere apart from low speed stuff such as parking.
I like it a lot, running redline in it.
Post by batou on Nov 15, 2020 9:38:32 GMT
This thread delivers, what an absolute animal this thing is Totally agree with you on the torsen vs plate diff, with this level of power or turbo applications in general a plate diff seems a much better choice, yes torsens are better than open diff but when your struggling for traction with a turbo and you have no grip/unloaded on one side then the transfer of torque to the other side, whilst it will transfer it will transfering 4x no grip . On lower power applications then a torsen is much more suited if your not smashing kerbs on a track... Heck, if it wasn't for the fact there isn't really a plated diff you can pop in the 1.6 VLSD housing without replacing the half shafts and the fact the ring gear is small I'd be tempted to do it. Torsen diffs are going for absolute silly money these days, far beyond their actual worth, which is why I'll be looking for a bargin 1.8 housing, driveshafts, prop and hopefully a decent ring gear/ratio and sticking in something like a 1.5/2 way Kaaz SuperQ in it when the oem one gives up (at stock 1.6 power most problems are easily fixed with sticky tyres ).
Post by Zed. on Nov 15, 2020 12:14:00 GMT
there isn't really a plated diff you can pop in the 1.6 VLSD housing without replacing the half shafts and the fact the ring gear is small I'd be tempted to do it. MazdaMotorsports sold a plate lsd for the earlier 6" diff (same used in early rx7 & 323gtx rear diff), got one in my '91 Eunos... although I will be replacing it with a 7" diff shortly.... Rich.
Post by niklas on Nov 20, 2020 17:25:06 GMT
The roads got icy today, so the car in in the garage for the winter. As usual, I have a list of things to do. Sadly, that starts with repairing the miss's corolla. It really is amazing how the roomy garage I had just.. filled up.
Post by niklas on Dec 1, 2020 14:16:34 GMT
Reading Batou's thread I had to get a set of these. They change the tone of the door closing. If they do anything more for my seam welded chassis I don't know, but they look nice and the door sounds chunkier now.
Post by batou on Dec 1, 2020 14:25:04 GMT
I have no bracing apart from the factory under braces and strut bar and I certainly felt less door rattle over bumps, but your right its almost a german car door clunk now Also, if they do nothing at least your helping the MX5 economy in Bulgaria
Post by suggs84 on Dec 1, 2020 15:16:18 GMT
Brilliant! That's two of us now who have bought those from the recommendation I'll second that about the much posher door clunk!
Post by niklas on Dec 5, 2020 13:59:04 GMT
I think the 6spd shifter has a much worse feel to it than the 5spd. One fix for this is installing the super expensive miataroadster shifter. That is a nice piece of kit that cures the notchy feeling and the moneyshift issue both at once. But of course I can't go with the tried and tested (or stomach the cost of the MR shifter). Instead I bought a raised fulcrum long shortshifter from fine cut. It looked like something that would fit my need but I couldn't find much about it online. The fabricator of it was nice and easy to get in contact with through facebook. The cost was reasonable. I received the shifter after a week or so. The machining was raw and it had some really sharp edges. I wasn't expecting it to be 100% for the price so that was ok. I spent a couple of hours polishing my lever in front of the tv. The result was what I want. Wetsanding even finer with say 1200 would get me a chrome finish, but I dont want that and the 600 finish is spot on for me. I think it looks the part in the car. I may weight the knob, delrin (I think) is quite light. Some slight modification of the rubber and leather boots was needed for the install. It has a really nice throw. The final verdict will as always come when used on track. The car needs to be run for a bit and have warm oil in the gearbox before I can tell exactly how it is. So far so good. First shift after install, mind that the lever is not fully lubricated in the socket. It's an old box.
Post by Zed. on Dec 5, 2020 14:23:51 GMT
some people like the raw machined finish, not my thing though at minimum it should be deburred & as an apprentace I'd have had the foreman on my case if I'd done anything anyway, hows the taller stick feel? I've always thought the standard item was a bit short Rich.
Post by niklas on Dec 5, 2020 14:48:19 GMT
anyway, hows the taller stick feel? I've always thought the standard item was a bit short Its the perfect spot for it. I really like the height.
Post by niklas on Mar 13, 2021 20:59:47 GMT
I'm doing nothing due to the kids taking all my spare time. But at least I've taken the opportunity to get some bling tools. I really need some time to work on the car, all my joy with it right now is imagining I will get time for it 😁
Post by zoona on Mar 23, 2021 11:10:38 GMT
Have you been watching AvE?
Post by atlex on Mar 23, 2021 11:36:54 GMT
oh gosh nepros!
Post by niklas on Mar 24, 2021 7:56:59 GMT
They really are everything I thought they would be. Also, I actually did something! And they even fit, welded nuts inside of the trunk. Decided on this placement due to being able to route the hoses completely outside of the car. The coolers will go on both sides outside of the pumps. I just got to get materials for the brackets. Oh, and they will be completely level when done.
Post by niklas on Mar 24, 2021 8:13:48 GMT
Have you been watching AvE? Heh, yup. His first nepros episode got me itching for them. I've been wanting to start a high end toolbox for some time.
