ITBs
Jan 29, 2017 22:25:43 GMT
Post by muckingfuppet on Jan 29, 2017 22:25:43 GMT
Anybody got pics of a set up where the throttle bodies are inclined upward to allow filters over the throttle bodies clear of the brake servo? Also links to build logs for homebrew setups?
Post by baconsarnie on Jan 30, 2017 10:30:35 GMT
Jenvey 1.6 kit is angled up. The standard 40mm trumpets fit with the corresponding sausage filter without problems with the brake servo. Clutch resevior is a tight squeeze however. Longer trumnpets will fit if the brake prop valve is repositioned. I'm mid way through doing this. Will post pics on my build thread soon.
ITBs
Feb 3, 2017 11:01:06 GMT
Post by Ptichka on Feb 3, 2017 11:01:06 GMT
Jenvey have drawings of their manifolds on their website, think it's a 20 deg incline.
Post by baconsarnie on Feb 6, 2017 12:22:43 GMT
Check out my build thread for the update on trumpet clearance
ITBs
Feb 8, 2017 10:58:53 GMT
Aaron likes this
Post by BikeTuna on Feb 8, 2017 10:58:53 GMT
I am desperate to be a part of this all, but with my other project on the go I cant realistically start fitting ITBs to mine for at least 6 months. Hopefully someone here is going to do a how to guide for when I'm finally able to get in on the game... (please!)
ITBs
Mar 10, 2017 19:56:46 GMT
via mobile
Post by robygodzilla on Mar 10, 2017 19:56:46 GMT
Thought I might chime in since I'm in the middle of an itb build screencast1.6 manifold chopped and gsxr 600 throttle bodies. Still work in progress though.
ITBs
Sept 23, 2019 20:50:51 GMT
Post by dickie on Sept 23, 2019 20:50:51 GMT
Being an Old Git.
I took the RS to the MX5OC Gaydon Rally the other weekend.
The driving challenge was awsome fun.
Whilst having a wander around the trade stall I found something very interesting on the BBR stand. They had a Mk2.5 fitted with Direct to Head ITBs which featured a built in Idle air control system. They displayed a Dyno Print out as well
They also had a set off the car but they were attached to the scuttle with tie wraps so I could not get a good fondle of them. ( I did ask the nice man if I could fondle his ITBs ) they looked well sorted except for the throttle cable connection which was in a position which would make it all but impossible to fit an airbox with the intake facing forward. This could be sorted out by the time they are officially released.
The have not been released yet this is a preveiw. They should be officially launched in the next couple of months. I will be watching the BBR website with interest. Could be a Chrimbo Pressy for the Project Car.
Post by dickie on Mar 24, 2020 19:17:09 GMT
Hi Folks, Just a heads up on my project ITB car, Its at the rolling road for full ECU tune unfortunately I had a phone call today to say that the company has gone into lockdown for three weeks. The good news is 172 BHP achieved so far, I do not know if a raised rev limit will gain more. Its at a 7500 RPM limit at the moment, if power is still building at the limit then a forged bottom end is on the cards.
Keep yourselves safe
Cheers Dickie
ITBs
Mar 24, 2020 20:00:39 GMT
Post by atlex on Mar 24, 2020 20:00:39 GMT
That's an epic result :-)
Post by dickie on Mar 24, 2020 21:10:01 GMT
You might find piccy here.
Shame the car is under Lockdown at the moment.
Post by dickie on Jun 3, 2020 16:10:16 GMT
My ITB Mongrel comes home on Friday I have booked its Mot for next Tuesday after work.
Post by dickie on Jun 5, 2020 18:49:11 GMT
Hi Folks, The Mongrel is now at home. After a bit more tuning for drivability we now have. 169.9 BHP @ 7400 Rpm 127 Ft Lb @ 6400 Rpm
ITBs
Jun 5, 2020 21:21:08 GMT
Post by atlex on Jun 5, 2020 21:21:08 GMT
ITBs
Jun 5, 2020 21:50:41 GMT
via mobile
Post by dadbif on Jun 5, 2020 21:50:41 GMT
I machined a new backplate for the ITG sausage filter so that it offset the filter away from my master cylinder when using Jenveys on a Westfield.
ITBs
Jun 6, 2020 11:29:13 GMT
Post by schercheeroo on Jun 6, 2020 11:29:13 GMT
Hi Folks, The Mongrel is now at home. After a bit more tuning for drivability we now have. 169.9 BHP @ 7400 Rpm 127 Ft Lb @ 6400 Rpm Do you have the spec of your engine posted somewhere Dickie? List of mods etc.
