gbuk
Post by gbuk on Jun 3, 2021 8:10:25 GMT
We have aan old Xreg Renault Espace which lives in the road outside and is useful for running the grandkids about, but has hardly turned a wheel for the last year. Charged up the battery last week and checked all was well for the MOT today. It started on the button but sounded rather sporty. Turns out there are some helpful roadside mechanics who come round and add lightness to cars by removing a section of the exhaust for you that used to house the catalytic converter. Not impressed Ls swap. You may as well Always been one of my dreams to stick a big engine in a first gen Espace. So wrong it's right.
Post by zoona on Jun 3, 2021 8:12:09 GMT
Ls swap. You may as well Always been one of my dreams to stick a big engine in a first gen Espace. So wrong it's right. That is cool... I was thinking a bit more stealth though!
Post by wannabe on Jun 5, 2021 19:14:34 GMT
Bahahaa That Espace is awesome!
Post by dadbif on Jun 6, 2021 18:40:54 GMT
Rerouted my MAP sensor input from front of inlet manifold to FPR.
Post by atlex on Jun 6, 2021 21:17:23 GMT
Rerouted my MAP sensor input from front of inlet manifold to FPR. Why ? Curious.
Post by dadbif on Jun 7, 2021 6:28:52 GMT
Because it allegedly gives a smoother output to the MAP sensor than using one of the spare vac sources at the front of the inlet manifold. Perceived wisdom on Megasquirt forums says so. Also considering the vacuum feed on my mini bypass valve, that is supposed to benefit from an input closer to the inlet manifold (according to mini tuners)
The devil makes work for idle hands etc...
Post by Zed. on Jun 7, 2021 9:43:08 GMT
Rerouted my MAP sensor input from front of inlet manifold to FPR. Why ? Curious. Because it allegedly gives a smoother output to the MAP sensor than using one of the spare vac sources at the front of the inlet manifold. Perceived wisdom on Megasquirt forums says so. Also considering the vacuum feed on my mini bypass valve, that is supposed to benefit from an input closer to the inlet manifold (according to mini tuners) The devil makes work for idle hands etc... ^^sorta this, taking reference from the opposite end to the throttlebody can give a smoother signal (alegedly) ideally away from the inlet-runners to lessen the pulsing affect.... same applies to pressure gauges Rich.
Post by batou on Jun 7, 2021 14:22:49 GMT
Just something to keep my rear canoe comfy...
Post by Zed. on Jun 7, 2021 14:51:12 GMT
Just something to keep my arse comfy... Some peopler have too much money obviously I'm NOT jealous Rich.
Post by batou on Jun 7, 2021 14:55:23 GMT
Some peopler have too much money obviously I'm NOT jealous Rich. Not enough for a pair though, so some people have even more (obviously I AM jealous)
Post by dadbif on Jun 7, 2021 15:54:33 GMT
Because it allegedly gives a smoother output to the MAP sensor than using one of the spare vac sources at the front of the inlet manifold. Perceived wisdom on Megasquirt forums says so. Also considering the vacuum feed on my mini bypass valve, that is supposed to benefit from an input closer to the inlet manifold (according to mini tuners) The devil makes work for idle hands etc... ^^sorta this, taking reference from the opposite end to the throttlebody can give a smoother signal (alegedly) ideally away from the inlet-runners to lessen the pulsing affect.... same applies to pressure gauges Rich. Well, after a thrash around today the MAP vacuum hose is going back to its original position, much hesitation going back onto throttle.
Post by suggs84 on Jun 7, 2021 16:00:41 GMT
Picked the car up from the garage, the new slave cylinder I provided sorted the clutch pedal issue it seems so fingers crossed, all good!
Post by zoona on Jun 8, 2021 14:53:04 GMT
Project must be nearly finished... i have a wing mirror (just one. Can't find the screws for the other side)
Post by wannabe on Jun 9, 2021 11:20:28 GMT
Just something to keep my rear canoe comfy... Those wings look like a snug fit!
Post by batou on Jun 9, 2021 11:32:08 GMT
Those wings look like a snug fit! Yup, they very lightly touch the door cards but they are not "squeezed" or pushed at all. Snug is the right word
