Post by howardb66 on Oct 19, 2022 7:37:35 GMT
non-destructively patched the g4x for a knock signal. will test this tomorrow. I’ve got to do something similar on my ME221 to get the EBC to work..🤨
Post by dadbif on Oct 19, 2022 7:47:27 GMT
Continued with my relentless search for another 5…. stupid as it sounds but........ waddyalookinfor? Rich. Torn between another MK1, in at least as good condition body wise as the one I stoooopidly sold, or a MK3 2.0. MK1 prices are ridiculous and MK3’s are equally prone to rust. Paid 1k for my previous 92 V Special.. cannot believe how much some people think their rust buckets are worth. I am becoming addicted to reading MOT histories…
Post by dadbif on Oct 19, 2022 7:49:41 GMT
“Bottom Row” depends on which way is up 😜
Post by scottydugg on Oct 19, 2022 8:20:28 GMT
stupid as it sounds but........ waddyalookinfor? Rich. Torn between another MK1, in at least as good condition body wise as the one I stoooopidly sold, or a MK3 2.0. MK1 prices are ridiculous and MK3’s are equally prone to rust. Paid 1k for my previous 92 V Special.. cannot believe how much some people think their rust buckets are worth. I am becoming addicted to reading MOT histories… Might not be relevant, but I didn't know BBR sold some of their previous cars HERE. The NC with the 2.5 and turbo, might be what you're after!
Post by dadbif on Oct 19, 2022 12:26:55 GMT
How much? They are having a laugh!
Post by atlex on Oct 19, 2022 13:24:05 GMT
Updated the pic above based on new/better info from Link.
Post by scottydugg on Oct 19, 2022 14:52:06 GMT
How much? They are having a laugh! l said to myself if I won the lottery I'd pick that up....numbers haven't come in yet.
Post by atlex on Oct 19, 2022 14:54:47 GMT
non-destructively patched the g4x for a knock signal. will test this tomorrow. I’ve got to do something similar on my ME221 to get the EBC to work..🤨 You shouldn't need to, you should just wire that up to the charcoal canister solenoid purge pins, which are already in the engine bay but on the wrong side.
Post by atlex on Oct 19, 2022 15:00:37 GMT
I’ve got to do something similar on my ME221 to get the EBC to work..🤨 Sneaky Humblebrag So you're destroying the competition without boost control ? XD
Post by howardb66 on Oct 19, 2022 19:21:22 GMT
I’ve got to do something similar on my ME221 to get the EBC to work..🤨 You shouldn't need to, you should just wire that up to the charcoal canister solenoid purge pins, which are already in the engine bay but on the wrong side. I’ve wired it up like you said & no boost control. A little more research & the very early black PCB me221s need a couple of terminals soldering.
Post by howardb66 on Oct 19, 2022 19:24:52 GMT
I’ve got to do something similar on my ME221 to get the EBC to work..🤨 Sneaky Humblebrag So you're destroying the competition without boost control ? XD Ha! 😬 Fortunately I’ve got a manual boost controller which works but compared to one run off the ECU, it’s rubbish. My friend Harry on here has exactly the same set up but with EBC & has +40 lbft torque.
Post by batou on Oct 19, 2022 19:26:53 GMT
Post by atlex on Oct 20, 2022 15:28:50 GMT
Took the G4X'd turbo smurf out for her first drive. Other than the Acceleration Enrichment being disabled (so a bit juddery at low RPM when I'm trying to speed up..) it's pretty much flawless.
I'm getting knock data from the knock sensor now. Next week I'll be replacing the loom for that with a properly shielded one when that arrives..
Fueling tweaks are easily done, very similar to the Kpro/Kmanager setup. Arguably better even than the Kpro setup.
Post by atlex on Oct 20, 2022 21:25:52 GMT
Now on the 4th iteration of the map. Did some WOT with wastegate pressure boost. No det yet detected. I need to revisit my high MAP AFR targets I think but other than that.. yay.
Post by atlex on Oct 21, 2022 22:34:00 GMT
been out doing some pulls to test boost control and fueling in the higher pressure regions.
such a smooth AFR curve - there's no curve at all really... it's practically flat!
the high res logging is ace and I can see the ECT goes from 92 at the start to 97 at the end (I should probably run thicker oil 5w40 ?) and then peaks later at 99 as the heated coolant works its way to the sensor, then comes down again quickly. this could be sensor ground but I can test that by dropping revs sooner at the end of runs.
I'm thoroughly impressed by the G4X - it's a really fast ECU. As the boost starts there is no beat skipped in fueling, typically an ecu is a little slow to catch up and you get a tiny harmless lean spike at the start. I'm not even running acceleration enrichment .. the curve is perfect without deformation... like I said, really fast ECU.
