Toby
Post by Toby on Jan 8, 2017 21:43:37 GMT
Made my self up a set of "COPS" using coils from a toyota celica, stronger spark and cheaper to replace - Winner! I'd found the car was running a little rich on WOT so booked the car in at Scuzzle just to see if the map needed looking at, turned out just to be wiring at the Air inlet sensor wich was happy days so decided to use the time to crank the b00st up! Never intended to be a numbers chasing game but when your so close to 300bhp it ended up being so! Basically found the limit of my turbo at about 19/20psi, end result below. This is wheel HP so equates to just over 290BHP which isn't a massive amount more than I had before in terms of peak power, but what I did get is 25bhp and 25ftlb more between 3000-6500rpm so happy days! It didn't come without its challenges though, they day after i'd been to the dyno I went to start the car up and it would not fire, after several emails and calls with various companies I got the gen on how to wire the coils up for sequential ignition, and after further trial and error yesterday we finally cracked it!
Toby
Post by Toby on Sept 8, 2017 20:48:46 GMT
Much updates needed! Car has been left a little forgotten in recent months but the love is still strong!
Toby
Post by Toby on Feb 11, 2018 14:46:38 GMT
Ditch the APR wing for a more retro themed ducktail, this one is a single peice YSCC (Your sports Japan) bootlid, really nice Quality item and I’m really happy with it. Also to try and make the car a little more comfortable I put an oem hardtop on, for the sake of 6kg or so it makes the inside a much nicer place to be! Got some R1r’s on the silver rims now to hopefully get some more sprinting actin out of this season! Cheeky vid from sprint Royale last year.
Joined the self-canoeer club with a private plate too so went pressesed for more retro vibes!!
Post by Horney on Feb 11, 2018 15:05:27 GMT
Looking good bud!
Post by mrwallace on Feb 13, 2018 13:03:11 GMT
Love the look of this and it has a great spec, must be a hoot to drive!
Post by atlex on Feb 13, 2018 14:35:25 GMT
I approve.
tsp
Post by tsp on Feb 13, 2018 22:00:23 GMT
So cool! I love the spoiler.
Are you the guy that bought the frame rails from me??
Post by NurseHolliday on Feb 14, 2018 10:35:51 GMT
GV panel and the YSCC ducktail are such a good combo!
Toby
Post by Toby on Feb 14, 2018 20:58:59 GMT
Cheers folks! - frame Rails yes could well be! Picked up on the way back from trax in Portsmouth!
Toby
Post by Toby on Feb 19, 2018 20:11:45 GMT
First event of the season on Sunday!
Post by apextwin on Feb 19, 2018 20:41:58 GMT
Sounds nice onboard - what mic you using ? external?
Toby
Post by Toby on Feb 19, 2018 20:43:07 GMT
Yes just a cheap external mounted on the rear bumper!
Post by apextwin on Feb 19, 2018 20:46:31 GMT
Cool are they easy to wire up? How have you mounted it / wired it in?
Toby
Post by Toby on Feb 19, 2018 20:56:37 GMT
Very simple mate just plugs into the go pro on the cage, and run a cable through one of the many holes in the rear bulkhead into the boot then through a drain hole that takes you underneath the boot outside the car next to where I clip the mic on the bumper!
tsp
Post by tsp on Feb 19, 2018 21:21:09 GMT
That video hurt my head! Fair play for remembering your way round and not smashing the car up!
