Post by howardb66 on Apr 27, 2023 7:09:21 GMT
Oh, forgot to say, I weighed the brakes & the Supermiata set is 4kg lighter per side. It’s mostly because the disc is much lighter.
Post by howardb66 on May 5, 2023 11:53:10 GMT
Does anyone know where the turret oil disappears to? Just checked mine & it’s drier than a dry thing.
Post by scottydugg on May 5, 2023 14:02:00 GMT
6 Speed? I think that shares oil with the box.
Think only 5speed needs the turret oil
Post by howardb66 on May 5, 2023 15:30:23 GMT
6 Speed? I think that shares oil with the box. Think only 5speed needs the turret oil It’s the 5 speed.
Post by atlex on May 5, 2023 17:50:37 GMT
I think the 5 speed's turret could be given something thicker, greasier.. and less likely to leak out. doesn't have to be the gearbox oil spec, there's almost no chance the turrent can leak fluid into the gearbox itself.
Post by howardb66 on May 18, 2023 9:21:35 GMT
Recently have had a couple of clutch issues- a massive slip when coming out of a hairpin & also stinky after driving down to Goodwood. Thought to myself it’s time for a new one… The one in the car is a Skuzzle one & has lasted well, plus put up with a lot of abuse: About 240 Hillclimb & sprint standing starts, plus a few trackdays & about 20k miles. So I spoke to RTS to make sure they had one in stock & ordered, was told they shipped overnight. Next day no clutch. Got called out to go to work in the following few days so emailed RTS again to divert order to my mate’s garage to fit it as I had run out of time. Couple of days later still no clutch. Getting desperate now & called RTS… No answer. No choice but to do what I should’ve done & get one from BOFI. They had it in stock & I collected that morning. Brilliant. Looking at the worn out clutch, the side facing the flywheel was just about on the rivets but the paddle side was not worn anywhere near as much. However the pressure plate was was pretty well worn too. Clutch is now being gently run in before a sprint this Saturday at Lydden Hill. Oh & also changed the gearbox oil with redline MT90 which silenced a slight noise I was getting, at the same time I did the Kaaz too.
Post by boggissimo on May 18, 2023 10:50:18 GMT
I'm still annoyed I've had to cancel my entry for Lydden on Saturday. It was pretty much the first event I booked for the season (and would have been my first with CM), and it has been on the calendar for months, but my wife managed to book our daughter's 8th birthday party on the same day. At least I'll get to muck about at Ninja Warrior with the kids though!
I'm booked to do a sprint at Rushmoor (near Aldershot) on Sunday instead, which won't be as good as Lydden. It's in our Speed League and I've never done it before so will still be interesting and good to get some more points on the board.
Post by scottydugg on May 18, 2023 13:27:17 GMT
No complaints from the BOFI clutch from me, hopefully puts up with the abuse you'll give it.
On the turret oil, I don't know where it goes but it always seems low when I check. not sure if the gasket on the turret top is delicate or needs changing frequently.
Post by howardb66 on Jun 9, 2023 13:12:53 GMT
Hmmm, the jury’s out on the clutch still- it feels a bit soft when I launch off the start line. The brakes though are flipping amazing, really really good. However, all was not well at Lydden. It felt like the car was really misfiring on full throttle upchanges & if I stamped on the accelerator, had to carry a lot of speed through the corners to make up for it. The journey home was a PITA as the misfire got worse. Only had to touch the throttle & was getting overboost leading to ECU triggered boost cut. Back in the garage, I spotted a slight crack in the downpipe. Jacked the car up & took it off- luckily a friend just up the road has a TIG & he fixed it for me. Whilst the DP was off & out of the way, I swapped from a hybrid arrangement of the near side engine mount being an IL Motorsport rubber one to a Skidnation Performance one. It made a huge difference having these on both sides & the NVH is nowhere near as bad as I thought it would be. I got the DP back from my friend & as it was off + I had some in stock, I lava wrapped it to try to prevent some of the underbonnet heat build up. I took the car for a drive after this & the flipping overboost was still there- balls! I popped in on my MOT guy, who is also a Subaru nut, & he lent me a pressure tester to play with. Immediately it was bloody obvious; the wastegate actuator was split & the wastegate wasn’t opening. After a quick call to Leigh at BOFI to make sure they had stock, I wizzed over there & collected a very shiny(!) Forge one. It was fitted that afternoon along with a new Turbosmart waste gate valve. Massive difference. After a bit of fiddling about to get the boost correct, the MX5 is back! 😁
Post by Zed. on Jun 9, 2023 18:30:08 GMT
Shiney things Rich.
Post by howardb66 on Jun 30, 2023 8:57:59 GMT
So, have been having a few issues with the turbo recently. It’s been running really hot, in fact hot enough to split the coolant hoses where they attach to the core via banjos. Thought I’d get the turbo refreshed by a local guy who is very knowledgeable about Subaru turbos. It turns out my turbo isn’t a TD04- it’s something smaller called a TF 035. So it’s taken a little bit of jiggery pokery to get turbines & compressors to fit. Whilst I was at it, I asked the Subaru bloke if he had any old water pipes lying about, he had & they are significantly different to the little banjos supplied in the kits. They are significantly longer & take the rubber pipe to metal pipe about 100mm away from the turbo, therefore hopefully making the joint more robust. I’ve also done a lot of testing on the EBC circuitry to try & get it to work, redone the soldering on the ECU & tested all the wiring- IT STILL DOESNT BLOODY WORK🤬 Looking at the map, the mixture looks a bit lean now so I’ve emailed Alex at Digitune for a full remap.
Post by scottydugg on Jun 30, 2023 11:28:19 GMT
Had a quick google of the comparison between a TD04 and TF035, interesting pictures HERE, looks like it's quite a bit smaller than a TD04. You must have zero lag? Considering a TD04 is smaller than a GT2554r and most of the internet say that's too small for 5!
Post by howardb66 on Jul 1, 2023 8:32:41 GMT
Had a quick google of the comparison between a TD04 and TF035, interesting pictures HERE, looks like it's quite a bit smaller than a TD04. You must have zero lag? Considering a TD04 is smaller than a GT2554r and most of the internet say that's too small for 5! Yes, the little turbo is instantly reactive to throttle input. The only downside is that the torque produced is a little lower at about 210ft/lbs than a TD04 but produces a broadly similar output of 235-242hp on the 5 rolling road sessions I’ve done.
Post by howardb66 on Jul 20, 2023 16:18:56 GMT
Had another go at the EBC with a friend who actually designs things like this & after a couple of hour’s testing & soldering, I now have a fully functioning EBC. At last!!! So, over the last week or so have had the car completely remapped by Alex at digitune.co.uk/ The boost delivery is completely different with the EBC as the controller doesn’t just target a boost limit then stops at that limit; it’s much more progressive, therefore hopefully more driveable. It feels like a night & day contrast. Additionally, Alex has worked on the idle, which is now 100% reliable which means I no longer have to heel & toe coming up to junctions. Totally recommend his remote mapping service.
Post by niklas on Jul 20, 2023 20:24:23 GMT
Are you running tps-based boost target? I found that to make my car much friendlier. It is really easy to drive with that. I'm unsure if it makes much of a difference with <300hp, but it is very easy to try, atleast with ms3
